Mathematical Induction (The inductive step)
To prove that for all n≥1, 10n - 1 is divisible by 9, the inductive step requires assuming that 10k - 1 is divisible by 9 and demonstrating that 10k + 1 - 1 is also divisible by 9. The key is to express 10k + 1 - 1 in terms of 10k - 1. By rewriting it as 10(10k - 1) + 9, it becomes clear that both terms are divisible by 9. This approach clarifies the relationship between the two expressions and allows for the completion of the proof. Understanding this algebraic manipulation is essential for successfully applying mathematical induction in this case.
pavel329
1. I don't understand how to prove this.
for all n≥1, 10n - 1 is divisible by 9.
3. I've done the basis step.
Now I'm on the inductive step.
I'm using (10k+1-1)/9=1.
I don't know where to go from there.
Using algebra just gets me down to 10k+1= 10. And I really don't think that's the answer.
All examples I've seen show me things like 1...2..3..n+1= n(n+1) or something along the lines. They already give me the equation. This one does not.
This isn't right. You need to show that 10k+1-1 is divisible by 9, not that it is equal to 9. There is a difference. For example, 27 is divisible by 9, but the two numbers aren't equal.
What do you have for your induction hypothesis?
Assume that 10k-1 is divisable by 9. Prove that it implies 10k+1-1 is also divisable by 9.
Try to bring 10k+1-1 to such form that it contain 10k-1.
10k+1=10*10k=> 10k+1-1=10*10k-1=10*10k-10+10-1=
10(10k-1)+9.
Can you proceed from here?
ehild
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
