Mathematicians modern rigorous definition of number?
  • Context: Graduate
  • Thread starter Thread starter roger
    Definition Rigorous
The modern rigorous definition of a "number" in mathematics is that it is an element of a defined "number system," which includes specific operations such as addition and multiplication. Different types of numbers—such as natural numbers, integers, real numbers, and surreal numbers—have distinct definitions based on their respective sets. The discussion emphasizes that while all quantities can be described by numbers, not all numbers represent quantities, particularly in the case of complex numbers like sqrt(-1). Ultimately, the definition of a number is contingent upon the operations and properties associated with its specific number system.
  • Understanding of number systems, including natural numbers, integers, and real numbers.
  • Familiarity with mathematical operations such as addition and multiplication.
  • Knowledge of advanced number types like surreal numbers and complex numbers.
  • Basic concepts of set theory and elements within sets.
  • Research the properties and definitions of surreal numbers.
  • Explore the concept of number systems in abstract algebra.
  • Learn about the operations defined on different types of numbers.
  • Investigate the implications of complex numbers in mathematical definitions.
Mathematicians, educators, students in advanced mathematics, and anyone interested in the foundational definitions and properties of numbers in various mathematical contexts.
roger
What is the mathematicians modern rigorous definition of number ?
thanks
Roger
Mathematics news on Phys.org
There isn't one!
If there is one, a "number" is an element of a "number system"
A "number system" is some set, associated typically by some "operations" that you can use upon the elements of the set, for example "adding" two of the "numbers" together.
This is my very informal view of this, however..
thanks
Roger
What type of number? A natural number? An integer? A quotient? A real number? A complex number? A hyper-real number? A hyper-complex number? A trans-finite number? A surreal number?...
All of these have different definitions.
Apparently it seems that a number is defined as being an element of some defined set.
It is quite funny that "element" and "number" mean the same thing. So in fact we can define anything we want as a number !
Some collection of things whose members we often refer to as numbers are not sets, to give you an example the 'surreal numbers' form a proper class (i.e. they do not form a set).
Element and number are not synonyms; it certainly is not common to call every member of a set (or a class) a number.
I didn't state which kind of number because, I didn't feel that it would ultimately make any difference to the question.
the last comment made is true I guess in the sense that the two words element and number, are equivalent in meaning.
is it wrong to define it as a quantity of things eg apples ?
That definition is misleading. You end up having to twist and distort it to an unrecognizable lump after encountering various number systems. Considering just the negative integers, you then have to modify it by "also an absence of quantity" or some other interpretation. It only goes downhill from there. What quantity does sqrt(-1) measure ? Then you start to redefine quantity until the original statement is meaningless. While all quantities may be described by numbers, not all numbers represent quantities. Some are quite qualitative.
No, no one said that- a "number" is an element of some specifically defined sets, not just any set! In order to be a "number system" the set must have other things associated with it- primarily operations such as addition or multiplication. Of course,mathematicians do, regularly, define such operations for all kinds of "things" so we could in a very specific way "define" anything we want as a number!
In fact to demonstrate such a thing one of my first lectures last year for a course started off by creating a set of cutlery and using them as numbers after defining addition and multiplication on them.
  • · Replies 20 ·
  • · Replies 58 ·
9K
  • · Replies 47 ·
