How Do You Solve These Challenging Math Competition Problems?
  • Thread starter Thread starter Kushal
    Competition
This discussion focuses on solving challenging math competition problems, specifically addressing inequalities, quadratic equations, and geometric configurations involving rectangles. The first problem involves the inequality |x - 2| < p, leading to the conclusion that x - p cannot be a specific number due to the conditions provided. The second problem seeks the coefficient 'a' for which the equations x² - ax + 1 = 0 and x² - x + a = 0 share a common real solution, with the correct value determined to be -2. The third problem correctly identifies that a rectangle allows for five distinct circles formed by pairs of vertices, clarifying the misconception that only six circles can be formed.
  • Understanding of inequalities, specifically absolute values
  • Knowledge of quadratic equations and their solutions
  • Familiarity with geometric properties of rectangles
  • Ability to manipulate algebraic expressions and coefficients
  • Study the properties of absolute value inequalities in depth
  • Learn about the discriminant of quadratic equations to determine common solutions
  • Explore geometric configurations involving circles and polygons
  • Investigate the relationship between the roots of quadratic equations and their coefficients
Mathematics students, educators, and competitive exam participants seeking to enhance their problem-solving skills in algebra and geometry.
Kushal
#1 If |x -2| < p, where x < 2, then x - p =
i have obtained an inequality at most.
#2 For what value of the coefficient a do the equations x2 -ax + 1 = 0 and x2 - x + a = 0.
#3 Let R be a rectangle. How many circles in the plane of R have a diameter both of whose endpoits are vertices of R?
#1 -p < x-2 < p
eventually i obtain:
-2p + 2 < x - p < 2
#2 I have tried solving simultaneously but i have obtained and equation with both a and x.
i have also tried equating coefficients but i obtain a = 1. The actual answer is -2.
#3 is that 6? because there are 6 different ways of joining 2 vertices in the rectangle.
thnks
i have obtained an inequality at most.p
That's all you can do. Certainly, given the conditions, x- p is not any specific number. For example, p=2, x= 1 and p= 2, x= 1/2 satisfy the conditions but in the first case x-p= -1 while in the second x-p= -3/2.
There is a verb missing! Those equation WHAT? Do you mean "for what value of a" are those equations true for the same x?
#1 -p < x-2 < p
-2p + 2 < x - p < 2
You haven't used the condition that x< 2. In fact, because of that x-2 is negative, |x-2|= 2- x and, since p is clearly positive, you should have -p< 2- x< p
What, exactly, is the question? You say the "actual answer" is -2. That would give x2- 2x= 1, which has 1 as its only root and x2- x+ 2 which has complex roots (1/2)+ i and (1/2)- i.
Yes, that sounds right. Any two points define a circle and there are 6 pairs of points. It is possible that in special cases two or more of those circles would be the same but the general case is 6.
thnks[/QUOTE]
sorry. the question is:
#2 For what value of the coefficient a do the equations x2 -ax + 1 = 0 and x2 - x + a = 0 have a common real solution?for #3 the booklet says the answer is 5. i don't understand how. it is a rectangle. so the pair vertices are all different!thanks!
I see. One solution must be the same, not necessarily both. Try this. Suppose the solutions to the first equation are "u", and "v" while the solutions to the second equation are "u" and "w". Then you must have (x-u)(x-v)= x2- ax+ 1 and (x-u)(x-w)= x2- x+ a. Multiply those out and set like coeficients equal to get 4 equations for u, v, and w. What value of a gives a solution?
But it is a rectangle and not 4 arbitrary points. Take a look at the 2 circles having diagonally opposite points as ends of diameters.
thank you HallsofIvy, i got the solution to #2.
but i still cannot understand how come the two circles with the diagonals of the rectangle as diameter will be the same.
The two diagonals of a rectangle have equal length and the same midpoint. A single circle with either diagonal as diameter goes through all four vertices and so has the other diagonal as diameter also.
  • · Replies 39 ·
