Maths Problem (Medium): Proving the Solution
  • Level: Undergrad
  • Thread starter alice22
    Medium
4 replies · 2K views · last reply
alice22
Equation: (sum from i=0 to n-1 of 10^i) squared equals sum from i=1 to n of i times 10^(i-1), plus sum from i=1 to n-1 of i times 10^(2n-i-1).
Use English to explain what this is showing.
Also prove it!
Also prove it!
I found this else where, so some of you may have seen it before.
Just expand the square and you are basically done. The i's in the rhs are the number of combinations which can produce that exact exponent.
alice22 said:
Equation: (sum from i=0 to n-1 of 10^i) squared = sum from i=1 to n of i times 10^(i-1) plus sum from i=1 to n-1 of i times 10^(2n-i-1).
Also prove it!
The simplest thing to do is to look at what it says for some small n- say n= 3.
[tex]\left(\sum_{i=0}^{3-1}10^i\right)^2= \left(10^0+ 10^1+ 10^2\right)^2= (1+ 10+ 100)^2= 111^2[/tex].
[tex]\sum_{i=1}^n i10^{i-1}= 1(10^0)+ 2(10^1)+ 3(10^2)= 321[/tex]
[tex]\sum_{i=1}^{n-1} i10^{2n-i-1}= 1(10^4}+ 2(10^3)= 1200[/tex]
It's easy to calculate that [itex]111^2= 12321= 1200+ 321[/itex].
[itex]11^2= 121[/itex], [itex]111^3= 12321[/itex], [itex]1111^2= 1234321[/itex] , etc.
Do you see the pattern?
[tex]\sum_{i=1}^{n-1} i10^{2n-i-1}[/tex]
is the first part- the 1234... Do you see how it is counting "down" because of the [itex]10^{2n-i-1}[/itex]?
[tex]\sum_{i=1}^n i10^{i-1}[/tex]
is the last part: 321
Yes that's basically it the first bit gives the last n digits and the first bit gives the first n+1 digits where the length is 2n+1
