MATLAB MATLAB Help -- how to ask user for 2 input variables
To create a MATLAB program that prompts users for input data points for linear regression, the inputdlg function is recommended for a user-friendly dialog box. A loop can be implemented to ask for multiple [x y] pairs, extracting the values into separate matrices for x and y. The input can also be captured using the INPUT function with the 's' argument, allowing for string input that can be parsed into numeric values. It's essential to handle potential input errors by using a TRY... CATCH... END block to ensure the program runs smoothly. This approach will help gather the necessary data points effectively for graphing.
sflesock
I have an assignment where we have to ask the user for a number of data points which then we will graph a linear regression.
Enter the number of input data points: 7
Enter [x y] pair for point 1: [1.1 1.01]
Enter [x y] pair for point 2: [2.2 2.30]
Enter [x y] pair for point 3: [3.3 3.05]
Enter [x y] pair for point 4: [4.4 4.28]
Enter [x y] pair for point 5: [5.5 5.75]
Enter [x y] pair for point 6: [6.6 6.48]
Enter [x y] pair for point 7: [7.7 7.84]
This is what the program should look like as we are asking the user for the inputs. (The brackets are what the user inputs). How should the code look to get 2 separate variables? Any help would be greatly appreciated!
Matlab provides you with the inputdlg function for these purposes. Here is the documentation:
https://in.mathworks.com/help/matlab/ref/inputdlg.htmlAt the prompt, you will get a dialog box asking you for the various inputs. Put your code into a loop, and for each set, ask for the values of x and y using the above function.
Matlab:
prompt = {'Enter x:', 'Enter y:'};
dlgtitle1 = 'Enter values for point ';
for i=1:7
    dlgtitle = [dlgtitle1, num2str(i)];
    answer = inputdlg(prompt, dlgtitle);
    %extract x and y from answer
end
The answer matrix will have the two input values of x and y. Just extract them into your matrix for x and y.
If you're looking to prompt for text input as in your example, you can use the INPUT function with the 's' argument, you can add parsing code yourself. The 's' option captures the input as a string, so it can contain anything. Like so:
Code:
question = ['Enter [x y] pair for point ', num2str(k), ' '];  % I'm assuming k is the point number.
userinput = input(question, 's');
xy = str2num(userinput);
That will work if the user properly formats their input as two numbers separated by a space or comma, but might throw an error if their input syntax is incorrect. So you should probably embed it in a TRY... CATCH... END block.
26K
11K
13K
