MHB Proving Properties of 2x2 Matrices
  • Thread starter Thread starter TheScienceAlliance
    Matrices Properties
The discussion focuses on proving properties of 2x2 matrices, specifically addressing three main problems. The first problem establishes that if matrix A has a main diagonal sum of zero, then A squared (A^2) is a scalar matrix. The second problem demonstrates that for any two 2x2 matrices A and B, the sum of the diagonal entries of the matrix product AB - BA equals zero. The third problem involves proving a relationship involving three matrices A, B, and C, given the results from the first two problems.
  • Understanding of 2x2 matrix operations
  • Familiarity with scalar matrices
  • Knowledge of matrix multiplication and properties
  • Ability to manipulate matrix equations
  • Study the properties of scalar matrices in detail
  • Learn about the implications of the trace of a matrix
  • Explore commutative properties of matrix multiplication
  • Investigate the Cayley-Hamilton theorem for 2x2 matrices
Mathematicians, students studying linear algebra, and anyone interested in matrix theory and its applications.
TheScienceAlliance
1. A is a matrix of order 2x2 whose main diagonal's entries' sum is zero. Prove that A^2 is a scalar matrix.
2. Given: A and B are two matrices of order 2x2. Prove that the sum of the entries of the main diagonal of AB-BA is zero.
3. A, B and C are three matrices of order 2x2. Given: A^2 is a scalar matrix and the sum of the entries of the main diagonal of AB-BA is zero. Prove that C (AB-BA) ^2= (AB-BA) ^2*C?
Hi and welcome to MHB! What have you tried for each of these? Which one would you like to start with?
A is of the form $\begin{bmatrix}a & b \\ c & -a\end{bmatrix}$ What do you get when you square that?
Let $A= \begin{bmatrix}a & b \\ c & d\end{bmatrix}$ and let $B= \begin{bmatrix}p & q \\ r & s\end{bmatrix}$. What is AB- BA?
If $A= \begin{bmatrix}a & b \\ c & d\end{bmatrix}$ then $A^2= \begin{bmatrix}a^2+ bc & ab+ bd \\ ac+ cd & bc+ d^2\end{bmatrix}$. Since $A^2$ is a "scalar matrix" $A^2= \begin{bmatrix}P & 0 \\ 0 & P^2\end{bmatrix}$ so $a^2+ bc= bc+ d^2= P$, $ab+ bd= ac+ cd= 0$.
Let $A= \begin{bmatrix}a & b \\ c & d\end{bmatrix}$ and let $B= \begin{bmatrix}p & q \\ r & s\end{bmatrix}$. What is AB- BA?If $A= \begin{bmatrix}a & b \\ c & d\end{bmatrix}$ then $A^2= \begin{bmatrix}a^2+ bc & ab+ bd \\ ac+ cd & bc+ d^2\end{bmatrix}$. Since $A^2$ is a "scalar matrix" $A^2= \begin{bmatrix}P & 0 \\ 0 & P^2\end{bmatrix}$ so $a^2+ bc= bc+ d^2= P$, $ab+ bd= ac+ cd= 0$.
Thank you very much for the response, sir.
In regard to #2 -- I calculated AB-BA.
However, I did not see how the sum of the two entries in the diagonal equal zero.
I obtained the following entries:
a11= rb-cp
a22=qc-dp
How should I proceed?
a11= rb-cp
a22=qc-dp
You need to look at that again.
I get [math](AB - BA)_{11} = (ap + br) - (ap + cq) = br - cq[/math] and [math](AB - BA)_{22} = (cq + ds) - (br + ds) = cq - br[/math]
-Dan
-Dan
I obtained the same result.
Thank you very much :)
Also, my bad. The "given" part in the 3rd question is not given.
The question is written as follows:
A, B and C are three matrices of order 2x2. Prove that C (AB-BA) ^2= (AB-BA) ^2*C.
You can use the results obtained in parts 1 and 2 in order to solve part 3.
Does this mean that A and B in part 3 are the same matrices used in parts 1 and 2 (as in, matrix's A diagonal's entries' sum is zero)?
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 33 ·
