Matrix33 in C++: Create, Add, Check & Program
  • Context: C/C++
  • Thread starter Thread starter mathmari
    C++
25 replies · 3K views
mathmari
MHB
Hey! :giggle:
I am looking the following exercise about C++.
(a) Create a class Matrix33 that describes a 2-dimensional $3\times3$ array of integers. At the construction of an element of the class allpositions of the array are initially zero (zero matrix). Implement methods to read and write values at the positions of tha array according to the line and column of each position.
(b) Implement a method IsDiagonal that checks if the array is diagonal.
(c) Support adding arrays by overloading the + operator. With data elements Matrix33 m1, m2; the array Matrix33 m3 = m1 + m2; will contain the sum of the arrays m1 and m2.
(d) Implement methods for reading array data from input and printing array data at output. Write a program that creates 2 elements of class Matrix33, reads their data from the input, adds them and prints the result of the addition to the output.
I searched online for some notes. Is the code as follows? :unsure:
Code:
#include <iostream>
#include <cstdlib>
using namespace std;
class Matrix
public:
    Matrix(); //Default constructor
    Matrix(int m, int n); //Main constructor
    void setVal(int m, int n); //Method to set the val of [i,j]th-entry
private:
    int m, n;
    int **p;
    void allocArray()
        p = new int*[m];
        for(int i = 0; i < m; i++)
            p[i] = new int[n];
Matrix::Matrix() : Matrix(1,1) {}
Matrix::Matrix(int m, int n)
    allocArray();
        for(int j = 0; j < n; j++)
            p[i][j] = 0;
Hey mathmari!
That works more or less.
However, the question asks for a class named Matrix33, which has its dimensions fixed to 3x3.
And the method setVal is missing a parameter to set the actual value, and it's also missing an implementation.
We're also missing a method to read a value in the matrix.
Furthermore, if we do new int[n](), then everything gets initialized to 0, so we don't have to do that explicitly then.
Or alternatively, we could just have an int a[3][3] as data member, although we need to memset it to 0 then. 🤔
So for the part "Create a class Matrix33 that describes a 2-dimensional 3×3 array of integers. At the construction of an element of the class allpositions of the array are initially zero (zero matrix). " do we do the following?
Code:
#include <iostream>
class Matrix33
int m[3][3];
memset(m, 0, sizeof m);
Or did you mean something else? :unsure:
That wouldn't compile.
Instead it should be:
Code:
#include <cstring>
class Matrix33
public:
  Matrix33() {
    std::memset(m, 0, sizeof m);
private:
  int m[3][3];
And actually, we can do:
Code:
class Matrix33
public:
  Matrix33() : m() {}
private:
  int m[3][3];
for the same effect. 🤔
Code:
#include <cstring>
class Matrix33
public:
  Matrix33() {
private:
  int m[3][3];
Code:
class Matrix33
public:
  Matrix33() : m() {}
private:
  int m[3][3];
Ok!
So do we have at question (a) the following?
Code:
#include <cstring>
class Matrix33
public:
  Matrix33() : m() {}
private:
  int m[3][3];
}; int main()
    int m[3][3], i, j, elem;
    cout<<"Enter the Array Elements: ";
    for(i=0; i<5; i++){
        for(j=0; j<5; j++){
                cin>>m[i][j];
                cout<<"\nEnter Element to Insert: ";
                cin>>elem;
                m[i][j] = elem;
    cout<<"\nThe New Array is:\n";
    for(i=0; i<6; i++)
        cout<<m[i][j]<<"  ";
    cout<<endl;
    return 0;
:unsure:
Did you try to compile it?
There are a couple of problems with it.
We can try for instance with https://wandbox.org. 🤔
Furthermore, the code you have in main() is not actually using the class Matrix33 is it? 🤔
I made some changes but I still get errors.
Code:
#include <iostream>
#include <cstring>
class Matrix33
public:
  Matrix33() : m() {}
private:
  int m[3][3];
}; int main()
    Matrix33 m[3][3];
    int i, j, elem;
    for(i=0; i<4; i++){
        for(j=0; j<4; j++){
                cin>>m[i][j];
                cin>>elem;
                m[i][j] = elem;
    for(i=0; i<4; i++){
        for(j=0; j<4; j++){
            cout<<m[i][j]<<"  ";
    return 0;
What else do we have to change? The main is not correct. Normally from the exercise we have to write this in a functionand not in the main, write? :unsure:
What else do we have to change? The main is not correct. Normally from the exercise we have to write this in a function and not in the main, write?
Matrix33 is already a 3x3 matrix, so we shouldn't write Matrix33 m[3][3] but just Matrix33 matrix. 🤔
We need functions in the class to get and set values.
Currently we only have the so called special constructor function Matrix33().
We need for instance int get(int i, int j) { return m[i][j]; } inside the class.
Then we can get the value at position (i, j) with matrix.get(i, j).
Note that we cannot use matrix.m[i][j] since m is private. 🤔
The code to read a matrix from stdin is actually part of (d).
We can keep the code in main() for now to verify that we properly implemented (a).
But it should be replaced when we get to (d). 🤔
So do we not insert the elements into the matrix with:
Code:
    for(i=0; i<4; i++){
        for(j=0; j<4; j++){
                cin>>matrix[i][j];
                cin>>elem;
                matrix[i][j] = elem;
:unsure"
No. The object matrix does not support indexing with matrix[i][j]. (Shake)
Btw, currently we are first trying to get matrix[i][j], which is not possible.
And then we get elem, which we subsequently try to assign to matrix[i][j].
So we're trying to read every element twice. :eek:
Instead we should just read elem and use for instance matrix.set(i, j, elem) to put it into the matrix. 🤔
Let's suppose for now that "elem = i+j" then dowe have the following?
Code:
#include <iostream>
#include <string>
#include <cstring>
class Matrix33
private:
    int m[3][3];
public:
    Matrix33(){
void SetCell(int i, int j, int val)
    m[i][j] = val;
void print()
    for(int i = 0; i < 3; i++)
        for(int j = 0; j < 3; j++)
            cout << m[i][j] << "  ";
        cout << endl;
}; int main()
int i,j, elem;
Matrix33 matrix;
for (i=0; i<3; i++){
    for (j=0; j<3; j++){
        elem=i+j;
        matrix.SetCell(i,j,elem);
matrix.print();
return 0;
If this is correct then we have to define the correct "elem" and write the main part inside the Class for question (a), or not?
:unsure:
It is fine for (a) as it is now. (Nod)
Just some nitpicks.
The method get() should have a name that matches SetCell().
For (a) we need that "getter" method, so we should call it from main() as well to verify that it works as intended. 🧐
What do you mean? You mean that they should have a similar name? :unsure:
Do you mean that what I have written in the main should be in a separate function? :unsure:
Yes. If we have SetCell() to set the value of a cell, then we should have GetCell() to get the value of a cell. 🧐
No. The main() function is fine. It's just that there should be a call to matrix.GetCell() somewhere to verify that it's there and that it works. (a) asks for such a method after all. 🤔
So do we use matrix.GetCell() to print the matrix instead of the function I defined above?
Sodowe do it as follows?
Code:
#include <iostream>
#include <string>
#include <cstring>
class Matrix33
private:
    int m[3][3];
public:
    Matrix33(){
int GetCell(int i, int j) { return m[i][j]; }
    m[i][j] = val;
};   int main()
int i,j, elem;
Matrix33 matrix;
        elem=i+j;
        cout << matrix.GetCell(i,j) << "  ";
    cout << endl;
return 0;
:unsure:
Yep. That works. (Nod)
So all these methods to read and fill the matrix are inside the class Matrix33, right?
How exactly are the elements with which we fill the matrix? Does it mean that that in line $i$ and column $j$ the element that is filled is $ij$ ? :unsure:
The method of part (b) is also inside class Matrix33 ? Or is this a separate method? :unsure:
The element in line $i$ and column $j$ is filled with $i+j$.
When we run the program that should be visible. 🤔
The word "method" means that it is a function inside a class.
So yes, the method of (b) should be inside class Matrix33. 🤔
Yes, I wrote in the program to fill the (i,j)-cell with $i+j$, but is this supposed to be like this by the exercise statement? It says "at the positions of tha array according to the line and column of each position.". :unsure:
It means that we need to have a method that allows us to set the value of a cell at a certain line and column.
The method SetCell() does that.
How it is implemented inside the class is actually arbritrary, as long as we can get the same element back with GetCell() with the same line and column.
And we can. 🤔
And we can. 🤔
Do we not havw to ask the user for the enrties of the matrix in (a) ? :unsure:
If yes, is the code as follows?
Code:
#include <iostream>
#include <string>
#include <cstring>
class Matrix33
private:
    int m[3][3];
public:
    Matrix33(){
    m[i][j] = val;
int main()
int i,j, elem;
Matrix33 matrix;
        cout<<"Give the (i,j)-element";
        cin>>elem;
    cout << endl;
return 0;
:unsure:
Question (a) does not ask for that, does it? 🤔
Ah part (d) asks for it. (Malthe)
I tried for part (a) till (c) the following:
Code:
#include <iostream>
#include <string>
#include <cstring>
//Question (a)
class Matrix33
private:
    int m[3][3];
public:
    Matrix33(){
    m[i][j] = val;
//Question (b)
bool isDiagonal()
    for (int i = 0; i < 3; i++){
        for (int j = 0; j < 3; j++){
            if ((i != j) && (m[i][j] != 0)){
                return false;
    return true;
//Question (c)
int Addition(m1[3,3], m2[3,3])
int i,j;
for (i = 0; i < 3; i++)
        for (j = 0; j < 3; j++)
            m[i][j] = m1[i][j] + m2[i][j];
    cout << "Sum of matrices\n";
    {    for (j = 0; j < 3; j++)
        cout << "\n";
Do we have define m1 and m2 at the beginning at "private" ? :unsure:
mathmari said:
//Question (c)
Nope. (Shake)
We should define Matrix33 m1, m2 in main().
And we should make sure that we can do Matrix33 m3 = m1 + m2 in main() as well.
We can do so by implementing a function named operator+(). 🤔
I have done the following for the whole exercise:
Code:
#include <iostream>
#include <string>
#include <cstring>
//Question (a)
class Matrix33
private:
    int m[3][3];
public:
    Matrix33(){
    m[i][j] = val;
//Question (b)
bool isDiagonal()
                return false;
    return true;
//Question (c)
int OperatorPlus(int x, int y)
    int z = x + y;
    return z;
};   //Question (d)
int main()
int i,j, elem,res;
Matrix33 m1,m2,m;
cout << "Enter the elements of matrix m1: ";
       cin>>elem;
       m1.SetCell(i,j,elem);
       cout << m1.GetCell(i,j) << "  ";
    cout << endl;
cout << "Enter the elements of matrix m2: ";
        cin>>elem;
        m2.SetCell(i,j,elem);
        cout << m2.GetCell(i,j) << "  ";
    cout << endl;
for (i = 0; i < 3; i++){
        for (j = 0; j < 3; j++){
            res = OperatorPlus(m1.GetCell(i,j), m2.GetCell(i,j));
            m.SetCell(i,j,res);
    cout << "\n";
return 0;
I still get some errors. I get:
Code:
prog.cc: In function 'int main()':
prog.cc:75:19: error: 'OperatorPlus' was not declared in this scope
   75 |             res = OperatorPlus(m1.GetCell(i,j), m2.GetCell(i,j));
prog.cc:82:22: error: no match for 'operator[]' (operand types are 'Matrix33' and 'int')
   82 |             cout << m[i][j] << "  ";
What does these errors mean? Is the rest correct at the code that I wrote? :unsure:
I don't see the code mentioned in (c). (Shake)
And (d) asks for methods to read and write the matrix. I don't see such methods. (Sweating)
Code:
There is no function named 'OperatorPlus'.
Instead Matrix33 has a method with that name.
To call it, we would need for instance int result = matrix.OperatorPlus(2, 3). 🤔
'm' is of type Matrix33. It means that we cannot index it with [i][j]. 🤔
