Max allowable force for simply supported I-beam with 1.5 safety factor
  • Thread starter Thread starter its.me.lah
    Beam Design Force
3 replies · 6K views
its.me.lah
Case:
-Simply supported beam with central load. L = 570cm
- I-Beam. Height = 15cm. Base = 15cm. Thickness = 1cm.
- Material = mild steel. Assuming E = 210GPa.
- Safety Factor = 1.5.
- F = 2000N.
With those information i had obtained the I = 16.56x10^6 mm^4.
Now i don't know how to calculate:
- the max allowable force before it fails.
- If F = 2000N, is it safe to use this beam.
Please help.
You will need to find the maximum bending moment in the beam as a function of F, then find the maximum bending stress under that maximum moment, using the maximum bending stress formula, which you should be familiar with. Now you must know the yield stress for the given material, which must be given to you, since such yield stresses depend on the type of mild steel you are using. Apply safety factor appropriately, watch units, and solve for the allowable load F.
Dear PhantomJay...i am totally lost with your solution...would you please explain further..
Actually this is not my homework..my company wants to design a gantry and they want me to calculate the maximum allowable force for the beam.
Thanx again..
