Max and min forces on an elevator.
To determine the maximum and minimum forces exerted by an elevator motor, the net force equation Fnet = Ft - Fg is used, where Ft is the force from the motor and Fg is the gravitational force. The gravitational force is calculated as Fg = mass x gravity (Fg = 4850 kg x 9.8 m/s²). For minimum force, when the elevator is at rest or moving at constant speed, Ft equals Fg. For maximum force, the equation incorporates the additional acceleration, leading to Ft = (mass x (gravity + acceleration)). Proper application of these formulas is crucial for accurate calculations.
yeyspaz
" A elevator with a mass of 4850 kg is to be designed so that the maximum acceleration is 0.0600 g's. What are the max and min forces the motor should exert on the cable?"
I converted the .0600 gs to .558 m/s/s, but when iplugged it into the F=ma formula i got the wrong answer? am i supposed to use another formula? :bugeye:
Yes.
I think you use Fnet = Ft - Fg
Where Ft is the forces the motor exerts on cable.
| Ft
| ______
Fnet | |
_______
| Fg
V
For the min Fnet = 0 so Fg = Ft so Ft = 4850 x 9.8
and the max Fnet = Ft - Fg
would be (4850)(0.06)(9.8) + (9.8)(4850) = Ft
I could be wrong because I'm crap at Physics but, eh, at least I moved your question to the top again.
You used the right equation but with the wrong variables. Think, on the way down gravity makes the elevater to accelerate at 9.8m/s/s so to cancel that out the moter needs to pull enough to accelerate the elevator upwards with the acceleration of 9.8 + .588 m/s/s. (this is what kirby said but I didn't see him until I posted)
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 33 ·
