Max Initial Separation for Meeting of Two Moving Bodies
The discussion focuses on calculating the maximum initial separation between two bodies moving towards each other with initial velocities v1 and v2, and constant retardation a1 and a2. The correct formula for this calculation is derived as option b: (sqr(v1 + v2)) / (2(a1 + a2)). Participants in the forum attempted to derive the solution using kinematic equations but found discrepancies in their results compared to the provided options. The key takeaway is that the maximum separation can be determined using the combined velocities and retardations of both bodies.
  • Kinematic equations of motion
  • Understanding of constant acceleration and retardation
  • Basic algebra and manipulation of equations
  • Concept of relative motion
  • Study the derivation of kinematic equations in detail
  • Learn about the principles of relative motion in physics
  • Explore advanced problems involving multiple moving bodies
  • Investigate the implications of constant acceleration in real-world scenarios
Students studying physics, particularly those focusing on kinematics, as well as educators looking for examples of motion problems involving multiple objects.
Mr Virtual
Two bodies move in a straight line towards each other at initial velocities v1 and v2 and with constant retardation a1 and a2 respectively at the initial instant. What is the max initial separation between the bodies for which they will meet during the motion?
(sqr -> square of , root ->square root of)
Options:
a) sqr(v1)/a1 + sqr(v1)/a2
b) sqr(v1+v2)/2(a1+a2)
c)v1*v2/root(a1*a2)
d)sqr(v1)-sqr(v2)/(a1-a2)
sqr(v) = sqr(u) + 2as
Let s1 = Distance traveled by object1 before it stops at last
and s2=Distance traveled by object 2 before it stops
0 = sqr(v1) - 2*a1*s1
s1= sqr(v1)/2*a1
s2=sqr(v2)/2*a2
Max dist=s1 + s2
However, this answer does not match with any of the options above. According to the book, the correct answer is option b.
Help!
My answer doesn't match too.
I did it like this:
[tex]t=\frac{v_{1}}{a_{1}}=\frac{v_{2}}{a_{2}},[/tex]
[tex]s_{1}=v_{1}t-\frac{a_{1}}{2}t^{2}=\frac{v_{1}^{2}}{a_{1}}-\frac{v_{1}^2}{2a_{1}}=\frac{v_{1}^{2}}{2a_{1}},[/tex]
[tex]s_{2}=v_{2}t-\frac{a_{2}}{2}t^{2}=\frac{v_{2}^{2}}{a_{2}}-\frac{v_{2}^2}{2a_{2}}=\frac{v_{2}^{2}}{2a_{2}},[/tex]
but the sum of the last two expressions doesn't match with the (b) option, for which you say that equals to:
[tex]\frac{(v_{1}+v_{2})^{2}}{2(a_{2}+a_{2})}.[/tex]
  • · Replies 16 ·
