Max Load for 12ft Steel Ladder on 65 Deg Angle
  • Thread starter Thread starter blake92
    Load
The discussion revolves around determining the maximum load a 12-foot steel ladder, constructed from HSS 1x1x1/8in square steel tubing, can support when positioned at a 65-degree angle. Participants explore various methods of analysis, including treating the ladder as a simple beam and considering different types of loads.
  • One participant suggests treating the ladder as a simple beam with a concentrated load at the center to determine the maximum load.
  • Another participant raises concerns about seeking advice on an anonymous forum for a potentially dangerous application, questioning the original poster's engineering background and insurance.
  • A participant agrees with the initial approach for analyzing transverse bending loads but notes the need to consider longitudinal compressive loads as well.
  • Some participants express skepticism about the adequacy of the analysis method, suggesting the use of modeling software like SolidWorks for stress analysis and emphasizing the importance of factors of safety.
  • Concerns are raised about the potential failure points of the ladder, particularly at the joints and rungs, which may not be adequately addressed by treating the ladder as a single beam.
  • One participant highlights the dynamic nature of loads, indicating that the load may increase when a person steps onto the ladder.
Participants express a range of views on the adequacy of the proposed analysis method, with some supporting it and others suggesting it is insufficient. There is no consensus on the best approach to determine the maximum load safely.
Participants note the importance of analyzing the joints and rungs of the ladder, as well as considering dynamic loading conditions, which may not have been fully addressed in the initial analysis method.
This discussion may be of interest to engineers, safety professionals, and individuals involved in ladder design or evaluation, particularly those concerned with load analysis and safety standards.
blake92
I am determining the max load a steel ladder can hold when placed on a 65 degree angle.
the ladder is 12 ft long and is made out of HSS 1x1x1/8in square steel tubing.
my idea was to treat it as a simple beam with a single concentrated load at the center "P". then once that was determined, to apply it to a triangle with "P" being the opposite side. id then solve for the hypotenuse which would be the max load straight down when the ladder was placed at the 65 degree angle.
Was i correct in going about it in this way or is there a better way to do it? Thanks in advance!
This doesn't sound good. You are asking for advice on an anonymous web forum to help you maximally load a ladder that people will be using? What if you get bad advice? What is your ME background, and what professional engineer certifications do you hold? What is your insurance situation to cover you if/when somebody gets hurt using something that you designed and built?
blake92: Your approach described in post 1 sounds correct for the transverse (bending) load. And there is also a longitudinal, compressive load (from the ladder midspan to the ground), which might need to be taken into account. Is this a schoolwork question?
The ladders already exsist and have been used for years. i was just asked to see what they can hold. So we know they can hold what they are needed for but i wanted to find out what the max they can hold.
like i said, the ladders are real. i was just asked to determine what they can hold.
I don't think your analysis method is exhaustive enough. If you have access to modeling software such as SolidWorks you can use the stress analysis software and find where the max stresses will be. Once you know this, you can work on finding a worst case scenario but please, be generous with your factors of safety, an old ladder made of square tubing to be maximally loaded sounds like a disaster waiting to happened.
I don't think this is a good idea at all. It may well fail at the joints, such as where the rungs connect to the side rails. These are being ignored if you treat it as a single beam. You really need to analyse the joints and the rung holding the load too, possibly with finite element analysis.
The load will also be increased by dropping it onto the rung as the person puts his foot down. There'll be quite a difference between dropping a metal object directly onto the ladder compared to cushioning it with the muscles and shoe soles of a person.
Sorry, for safety reasons, this thread is closed.
12K
31K
28K
  • · Replies 48 ·
13K
  • · Replies 264 ·
33K
