Maximize Range of Dropped Ball from a Wedge
  • Thread starter Thread starter IHateMayonnaise
    Ball Range Wedge
The problem involves optimizing the height \( h' \) and angle \( \theta \) of a wedge to maximize the range of a ball dropped from a height \( h_0 \). The discussion centers around the application of physics principles such as conservation of energy and momentum, as well as kinematics.
  • Participants discuss using calculus of variations and partial derivatives to find optimal values for \( h' \) and \( \theta \). There are questions about the correctness of derived expressions and the complexity of differentiation. Some suggest using conservation of momentum and consider the implications of angle on the optimization of height.
There is an active exploration of different methods to approach the problem, including the potential for analytical versus numerical solutions. Participants are questioning assumptions about the relationship between angle and height, and some guidance has been offered regarding the use of conservation laws.
Participants note the absence of drag effects in their considerations and discuss the implications of fixed versus movable ramps on the optimization problem.
IHateMayonnaise
I'm attaching a drawing depicting the problem, hopefully the mods will approve it soon. In words: A ball is dropped from some height h_0 and hits a point on a wedge at some angle \theta at some height up the wedge h^\prime. Optimize h^\prime and \theta for which the range is maximized.
My first reaction is to use calculus of variations, however I'm not quite sure this is a viable option, as I don't really see any constraints that I could use to create some Lagrange multipliers. The problem basically boils down to "if someone throws a ball at an angle \theta with an initial velocity v_0 while standing on a cliff of height h^\prime, find the max range."
The velocity can be found by conservations of energy:
mg(h_0-h^\prime) = 1/2 m v^2 \rightarrow v = \sqrt{2g(h_0-h^\prime)}
Applying kinematics along the y-direction to get the time, then doing kinematics along the x direction I arrive at (haven't check this, but this isn't the problem):
<br /> \Delta x = \frac{\sqrt{2g(h_0-h^\prime)}\cos\theta}{g} \left[\sqrt{2g(h_0-h^\prime)}\sin\theta - \sqrt{2gh_0\sin^2\theta + 2gh^\prime\cos^2\theta}\right]<br />
Assuming this is correct, and I'm not saying it is, what would I do? How would I go about optimizing this? I am looking to find/optimize both h^\prime and \theta. Would I take the derivative with respect to h^\prime and set it equal to zero to find the best value? Would there be an easier way?
Thanks yall
IHateMayonnaise
Assuming your expression for \Delta x is correct, the way to proceed is to take partial derivatives with respect to h' and \theta and set each equal to zero. You will thus have two (nonlinear) equations in two unknowns to solve.
[edit] I think your expression for \Delta x isn't correct. If you let h'/h0 = a and factor h0 from the right side (in brackets), the value of the right side in brackets is negative for all values of a between 0 and 1 for a reasonable value for \theta (e.g. 45 degrees).
Thanks for the reply hotvette.
I was afraid you were going to say that; as you can see this expression is not so fun, differentiably speaking. I checked my work and there were a couple mistakes, but it is equally disgusting. I differentiated in Mathematica, set them equal, and it can't solve it. My thoughts: I must be doing this wrong. I am fairly sure that there must be an analytical solution to this, and I would hate to have to have a numerical one...
Have you tried using conservation of momentum to find the angle \theta? There are also some things you can assume about it to give maximum range.
I don't mean to be a lazy moocher, but can you be a bit more specific?
Correct me if I'm wrong, but if you assume no drag and only gravitational effects, from Dynamics an object shot in the air at an angle has a maximum range when the angle is 45 degrees. If you include drag effects its somewhere between 20 and 30 degrees.
Also, you must be able to use conservation of momentum with 2Dof to find an expression for \theta to optimize h&#039;.
I think viscousflow makes a good point about the optimum angle being 45 degrees, but that would be true only if the angle doesn't also affect h'. In other words, if the ramp were fixed horizontally and hinged, different angles would affect h'. But, if the ramp can also be moved right/left, then h' wouldn't depend on the angle. In the end I think you may have a single variable optimization problem.
  • · Replies 21 ·
