Maximizing Comfort and Efficiency: Tips for Heating Your Home
  • Thread starter Thread starter Andrea Vironda
    Heat
The discussion revolves around strategies for maximizing comfort and efficiency in home heating, particularly in the context of a single-person household in Italy using methane for heating. Participants explore various methods to improve heating efficiency, address heat loss, and maintain comfortable indoor temperatures.
  • One participant discusses their heating habits and queries about upgrading old window frames for better efficiency.
  • Another participant emphasizes the importance of ensuring that combustion air for the heater comes from outside to avoid efficiency losses and suggests various insulation and sealing techniques for windows and doors.
  • Several participants share insights on the impact of window types and insulation on heat loss, with suggestions for DIY solutions like storm windows and window films.
  • There is a discussion about the appropriate indoor temperature range for comfort and health, with differing opinions on what constitutes a healthy living temperature.
  • One participant mentions personal preferences for lower indoor temperatures and the use of additional clothing and bedding for comfort.
  • A suggestion is made to calculate the energy balance of the house to understand heat loss better, with a step-by-step approach to measuring and calculating heat loss and heater efficiency.
Participants express various opinions on the ideal indoor temperature and methods for improving heating efficiency. There is no clear consensus on the best practices, as different strategies are proposed and debated.
Some participants reference specific local practices and products that may not be universally applicable. The discussion includes assumptions about the effectiveness of various insulation methods and the impact of personal comfort preferences on heating strategies.
This discussion may be of interest to homeowners looking to improve heating efficiency, individuals considering home insulation options, and those curious about the relationship between indoor temperature and comfort.
Andrea Vironda
TL;DR
Advices to keep the house warm
Good morning,
I have a 90 mq house burning 1200 smc of methane every year.
I live alone and i keep 20°C when I'm at home (evenings) and 18.5°C when I'm not.
My window frames are quite old, and I don't know very well if it's the case to spend 8 monthly payments to update my hardware.
What is your suggestion?
You mentioned methane for heating, that indicates a flame is involved. The air for combustion should come from outside the area you are trying to heat.
This may require adding an air duct to the heater to supply outdoor air. If the heater uses indoor air you get a slightly lower air pressure indoors than outdoors which means cold outdoor air is coming into supply the heater; that is counter-productive and a real efficiency killer
Other than that, the two biggest heat losses from older homes are usually around the windows when windy and thru the glass without wind. Storm windows will help both conditions. Some people build their own using clear plastic film, it is much easier to work with and cheaper than glass. It has to be fairly thick to withstand the wind. The dead air space between the window and storm window does a surprisingly good job. Be sure to have some venting from the dead air space between them to the outdoors to avoid moisture build-up.
Plug any gaps between the window and the window frame, felt works well -- or newspaper or plastic bags can be used but they are a bit of a fire hazard and fall apart rather frequently (the only way I've found to clean up the bits is with a vacuum cleaner).
Of course weather stripping on the exterior doors is also needed, don't forget the bottom edge of the door, that often has a large gap.
Next would be to add insulation above the ceiling and maybe on or under the floors if practical. Additional carpeting is one approach for the floor, even if it is only several throw rugs. Cover as much area as you can manage. Or more work is to put padding under existing carpets if there isn't any. Adding padding to existing padding would likely not be worth the cost or effort.
The next step, being the most difficult/expensive, is to insulate the walls.
One way to track down where drafts are coming in is to light a candle and carry it around to possible leaks. You can also use smoldering newspaper.
Roll up some newspaper fairly tight, light one end of the roll, then blow out the flame. The paper will continue to emit smoke as it continues to burn as 'hot coals.'
Also pay attention to where the smoke exits. When the wind changes it can come in there.
Cheers,
Tom
I see you are in beautiful Italy. What kind of house do you have? Is the amount of methane you use a lot or a little compared to similar houses in your area?
I have a lodging in a block of 4. Mine is in the lower floor. exposed to east in the living side and to north in the night side.
The average italian consumption is 4% more than minee, but since I'm single and I work/run for the most of the day, my consumption is very high.
A family living in another lodging of my condominium burn 700 smc/yr, but they are in 4, with 2 kids and using the house most of the day. Upper floor, living side exposed to south and the night one exposed to west. New windows and boiler (mine is of 2004 i think).
Many people turn off the heat when they are not at home during the day.
Also, many people turn down the heat at night because they sleep a little better, you can always add a blanket if needed.
About the only thing left is when you are home, add another layer of clothing, such as a long sleeve shirt. (My wife likes it a few degrees cooler than I do, so I often have to wear an extra shirt at home.)
Your neighbor has the advantage of extra heating from a South facing unit, more people; and probably more active too!
Please keep us updated of what action and results you get -- it could be helpful for others too.
Cheers,
Tom
I think there's a limit below which living becomes unhealthy. I could control it with a thermometer and a hygrometer. 18C–21C is the comfort zone, i think below 18C is better not to go
Billions of people live outside those temperature ranges. It is a matter of acclimation.
https://www.ncbi.nlm.nih.gov/books/NBK535290/
Discussion
The PHE review concluded that heating homes to at least 18°C in winter poses minimal risk to the health of a sedentary person, wearing suitable clothing. It found this threshold to be particularly important for people over 65 years of age, or with pre-existing medical conditions, but allowed that healthy people aged 1 to 64 years might wish to heat their homes to slightly less than 18°C if they were wearing appropriate clothing and were active (during the day); or with sufficient bedding, clothing and thermal blankets or heating aids as appropriate at night.
On a personal level, my wife and I greatly prefer a slightly colder temperature. In the winter our house naturally stays at 10-15°C. Down jackets and hats in the morning, snuggly comforters on the sofa at night. Whether this affects our health I cannot say, but it makes us happy.
<snip>
Excellent post with lots of tips by Tom. :smile:
One way to cut down on heat loss through single-pane windows is to add clear window film:
https://www.amazon.com/dp/B00002NCJI/?tag=pfamazon01-20
I don't know if that is easily available there in Italy where you are, but it's worth looking into.
Also, my local power utility here in the US offers free in-home evaluations to help us reduce our power bills. Maybe check with your local utility to see if there are similar free evaluations available to you.
https://www.pge.com/en_US/residenti.../home-energy-checkup/home-energy-checkup.page
I was always aware that most heat is lost through the ceilings into the roof space or through an uninsulated roof. Rolls of fibreglass wool are fairly cheap and can be rolled out over the loft floor by any enthusiastic DIYer.
Air carries a lot of heat out of houses too, gaps in doorways and walls are bad causes of heat loss. I think fancy double glazing of old windows is very popular with salesmen but secondary double glazing is often suitable for DIY and the materials need not cost too much.
Convection, conduction and radiation can be put in that order as the culprits, in most cases.
Your profile says that you have a Master's degree in Mechanical Engineering, so the recommended approach is to calculate an energy balance for your house.
Step 1: Calculate the total heat loss on the coldest day. It's the sum of the heat loss through the walls, foundation, ceiling, windows, doors, and air leakage. It is recommended to use a spreadsheet for this so you can test the effect of various changes.
Step 2: Knowing the heat rating and efficiency of your heater, calculate the heat output if it has a fixed heat rate. A modulating heater is a little more challenging. Measure the percent run time on a cold day, and use that to calculate the heat sent to your house. This is your measured heat loss.
Step 3: If the calculated heat loss matches the measured heat loss, you can use your spreadsheet to calculate the effect of various changes. If it does not match, you need to work on your heat loss calculations and/or improve your heat loss measurement.
If you have difficulty understanding how to do all of this, just get started and do what you can. Continue until you are completely stuck, then we can help you proceed.
@Andrea Vironda if you want to go hi tech then some serious planning is called for. Once you have remote controlled heating (a good idea) then your choice of system needs to be as future proof as possible and integrated with all those other sexy facilities like door bells and security, controllable cooking etc etc,
Another point is to over design the radiators from the start so low temperature sources will keep you comfy.
But insulation is no.1 priority.
14K
14K
