Maximum area for inscribed cylinder
4 replies · 3K views · last reply
Elias Waranoi
Inscribe in a given cone, the height h of which is equal to the radius r of the base, a cylinder (c) whose total area is a maximum. Radius of cylinder is rc and height of cylinder is hc.
A = 2πrchc + 2πrc2
r = h ∴ hc = r - rc
A = 2πrc(r - rc) + 2πrc2
To get the maximum of this area I will find the radius rc when the growth of the area is zero.
dA/drc = 0 = 2πr
What does this result mean? I don't understand how 0 = 2πr makes sense as a result from a derivation. What kind of information does this result give me geometrically? How can I know that there is no maximum area to the cylinder as my answer sheet tells me.
Check your result for dA/drc
[edit] oops, I checked my result and now we agree. Looks as if the area does not depend on rc -- as I could have read in your post :rolleyes:
[edit] oops2 Thanks Ray for putting me right -- dA/drc does not depend on rc but the area itself of course does. It just keeps increasing until rc hits r and then you have a pancake, not a cylinder any more. Tricky exercise if you are doing it before coffee o0)
A = 2πrchc + 2πrc2
r = h ∴ hc = r - rc
dA/drc = 0 = 2πr
Your problem is constrained: ##\max f = r_c h_c + r_c^2## subject to ##r_c+h_c = r##. The objective is ##A/(2 \pi)## and the constraint arises because the cylinder is inscribed in a cone of base-radius and height ##r##. You can substitute ##h_c = r - r_c## into ##f## to get a one-dimensional problem ##\max f_1 = r_c^2 + r_c(r-r_c) = r r_c,## subject to ##0 \leq r_c \leq r##. What is the solution to this last problem? (Remember that ##r## is a constant, so ##r_c## is the only variable.)
Ray Vickson said:
Your problem is constrained: maxf=rchc+r2cmaxf=rchc+rc2\max f = r_c h_c + r_c^2 subject to rc+hc=rrc+hc=rr_c+h_c = r. The objective is A/(2π)A/(2π)A/(2 \pi) and the constraint arises because the cylinder is inscribed in a cone of base-radius and height rrr. You can substitute hc=r−rchc=r−rch_c = r - r_c into fff to get a one-dimensional problem maxf1=r2c+rc(r−rc)=rrc,maxf1=rc2+rc(r−rc)=rrc,\max f_1 = r_c^2 + r_c(r-r_c) = r r_c, subject to 0≤rc≤r0≤rc≤r0 \leq r_c \leq r. What is the solution to this last problem? (Remember that rrr is a constant, so rcrcr_c is the only variable.)
Sorry, bad title. What I'm looking for is the maximum in the curve of the growth of area for a cylinder inscribed in a cone. Not the maximum area. What I'm hung up on the result of my derivation dA/drc = 0 = 2πr. If for example my cone had the radius r of 1 meter than my derivation would give dA/drc = 2πr = 6.28 = 0 which doesn't make sense. But dA/drc = 0 is just a statement I made and if dA/drc ≠ 0 then that means my statement is false and there is no maximum or minimum in the growth of area for the cylinder. Seems like I figured it out while writing me reply... Sorry for wasting your time and thank you all for trying to help me!
Setting the derivative to zero is a mistake: you have a constrained problem! That is, your originally-described problem is
$$\begin{array}{l}\max A(r_c) = 2 \pi r_c(r-r_c) + 2 \pi r_c^2 = k r_c, \\
\text{subject to} \;\;0 \leq r_c \leq r.
\end{array}$$
Here, ##k = 2 \pi r## is a positive constant.
Your newly-described problem is to maximize the constant ##k## on the set ##0 \leq r_c \leq r##, which makes no sense: the area just keeps growing at a steady rate, so every point is a maximum growth rate point.
Setting a derivative to zero is what you do when you are looking for an interior-point max or min of a function, but not when you are on the boundary of an inequality constraint set. You would never, ever solve ##\max/ \min f(x) = 2x, \: 0 \leq x \leq 1## by setting the derivative of ##2x## to zero.
