Maximum possible speed of explosion fragments
The discussion revolves around determining the maximum speed of explosion fragments A, B, and C after an explosion, with C expected to achieve the highest velocity. Participants debate the conservation of momentum and kinetic energy, emphasizing that the total kinetic energy post-explosion must equal 1.5 times the initial kinetic energy. There is contention over whether A and B should move to the left while C moves to the right, with some arguing that this configuration may not yield the maximum speed for C. The conversation also touches on the complexities of solving the equations governing the system, suggesting that a configuration where A and B have equal speeds might maximize C's velocity. Ultimately, the problem is recognized as challenging, requiring careful consideration of both momentum and energy conservation principles.
songoku
An object moves with speed of 500 m/s then explodes to three equal parts causing the kinetic energy to increase by a factor of 1.5. What is the maximum possible speed obtained by one of the three part?
Let say the object explodes to three identical parts A, B, and C and initially the mass moves to the right before explosion.
To obtain maximum possible speed (I assume C is the one with maximum speed), I imagine C should move to the right and A and B both should move to the left. Is this correct?
Thanks
Likes etotheipi
I think you have to take into account that the total kinetic energy of the three parts with mass m, will be equal to 1.5 times the initial kinetic energy of ##\frac{1}{2}M(500\frac{m}{s})^2## of the mass ##M=3m##.
So I am not sure that your configuration will yield the maximum possible speed for C because in this configuration the kinetic energy will be split in three (not necessarily equal) parts. This problem looks a bit hard, are you sure you have given us the complete statement of the problem?
Likes songoku
Delta2 said:
I think you have to take into account that the total kinetic energy of the three parts with mass m, will be equal to 1.5 times the initial kinetic energy of 12M(500ms)212M(500ms)2 of the mass M=3mM=3m.
I don't think there's any difficulty with @songoku's plan.
If C gains velocity v then each of the others loses velocity v/2. No other way of adjusting the velocities of A and B will give C as much boost.
If no external force causes the explosion then kinetic energy of the system cannot increase, it can remain same or it can decrease (when the explosion causes the environment to heat up). To increase the energy of the system we must do some work on it but in your case nothing external is given.
Likes songoku
I think we are supposed to assume there was chemical energy available..
Likes songoku and Adesh
Yes, that may be the possibility.
Likes songoku
You are wrong here, kinetic energy of a system can increase (or decrease) due to internal forces, the momentum cannot change due to internal forces.
Example: Two charges that attract (or repulse ) each other. If we don't stabilize them the kinetic energy of the system will increase due to internal coulomb forces.
Likes songoku and etotheipi
@Adesh your post #4 would be correct if instead of "kinetic" energy at the first sentence you had said just energy or total energy.
Likes songoku, etotheipi and Adesh
But when we hold them in an unstable position its we who have provided them the potential energy.
Likes songoku
Yes I accept that I was not very clear, but as the original post involved only Kinetic Energy, I meant that total energy of the original post which was kinetic.
I would like to be sorry for an unclear post.
Likes songoku
There is hidden chemical potential energy in this problem, so the total energy is Kinetic+chemical.
Likes songoku
You are a bit unclear here, I was having in mind that the configuration that will yield max speed for C is ##v_A=v_B=0## why this is not the case?
Likes songoku
Momentum conservation means you might be able to get more. As against that, you might find that stopping A and B dead means too much net KE is gained.
Likes songoku
Yes there seems to be a tradeoff, if A and B gain/lose speed then C will gain/lose some speed because of conservation of momentum, but it will lose/gain some speed because of conservation of kinetic(+chemical) energy.
Likes songoku
Yes that is the complete statement of the question.
I have checked the case where the final speed of A and B = 0. It means that by conservation of momentum, C will gain three times the speed of M (initial object before explosion) and the final kinetic energy will be three times of previous so as both of you suspected, the gain in KE is too much.
So based on that case, I think my initial thought (A and B move to left and C to the right) is not possible because C will have speed higher than when the case where A and B stop, meaning that the ratio of KE will be higher than 3My other thought is to consider 2-D momentum, where C moves to the right, A moves to upper left making angle θ with respect to horizontal and B moves to lower left making angle β with respect to horizontal.
I am not sure this is the case because there are too many unknowns (final speed of A,B,C and also θ and β), unless I take θ = β but can I do it? I also do not know whether this will result in C gaining highest speed possible.
Thanks
songoku said:
Yes that is the complete statement of the question.My other thought is to consider 2-D momentum, where C moves to the right, A moves to upper left making angle θ with respect to horizontal and B moves to lower left making angle β with respect to horizontal.
Thanks
That's why I said that this problem seems to be hard. All the possible configurations for the velocities of A,B,C involve 2D or 3D momentum.
However I think that your original scenario might be the one that gives the maximum speed for C(that is A,B,C all moving along the same line, let's say x-axis, with C towards the positive x-axis and A,B towards the negative x-axis). You just have to take into consideration conservation of kinetic energy and not only conservation of momentum when solving the equations for the final speeds of A,B,C.
Likes songoku
They only need to move to the left relative to their prior motion. If you take the plunge and solve the equations according to your original thought you will get the answer; it just won't be quite what you expected.
Likes songoku
@haruspex it seems to me that we will have 3 unknowns (the velocities of A,B,C) and two equations (one from each conservation principle). Do we further assume that ##v_A=v_B##?
Likes songoku
In principle, it is not necessary to assume anything; there must be a maximum achievable speed subject to the given constraints. But a rigorous solution might be rather painful.
It is intuitive that the three will stay in a straight line, which gives us just three unknowns for the velocities. We have the final KE per unit mass and final velocity sum. Maximising the final velocity of C is the third equation.
But I think it is also fairly clear that A and B will turn out equal.
Likes songoku, jbriggs444, etotheipi and 1 other person
Ok so, let:
M = mass of object before explosion
m = mass of each part after explosion = 1/3 M
vA = speed of A after explosion (move to the left)
vB = speed of B after explosion (move to the left)
vC = speed of C after explosion (move to the right)
Conservation of momentum:
M . 500 = 1/3 M . vC - 1/3 M . vA - 1/3 M . vB
1500 = vC - vA - vB
vA = vC - vB - 1500 ... (i)KE final = 1.5 KE initial
1/2 . 1/3 M . vA2 + 1/2 . 1/3 M . vB2 + 1/2 . 1/3 M . vC2 = 3/2 . 1/2 . M . 5002
2 vA2 + 2 vB2 + 2 vC2 = 9 . 5002
2 (vC - vB - 1500)2 + 2 vB2 + 2 vC2 = 9 . 5002
2 vC2 + 2 vB2 + 2 . 15002 - 4 vC . vB - 6000 vC + 6000 vB + 2 vB2 + 2 vC2 = 9 . 5002
4 vC2 + 4 vB2 + 2 . 15002 - 4 vC . vB - 6000 vC + 6000 vB = 9 . 5002
How to proceed after this?
Thanks
songoku said:
Ok so, let:
1500 = vC - vA - vB
Thanks
How do you find the max of one variable as you vary another?
Likes songoku
1st derivative = 0? You mean I take derivative of the equation with respect to vB?
Thanks
Yes but you got to be carefull of what thing's 1st derivative you going to take. I think you first have to transform the equation to ##v_c=f(v_b)## where f some function that will have square roots (I am afraid) and then solve ##f'(v_b)=0##
Likes songoku
I think there is a way to show that the maximum of ##v_c## will happen when $$v_a=v_b$$. So plug this at your two equations $$1500=v_c-v_a-v_b$$ and $$KE_{final}=1.5KE_{initial}$$ and see what you get.
Likes songoku
After doing the derivative, I got vA = vB then after substituting back, my answer for maximum possible speed of C is 1000 m/s
How can I be sure that this is the maximum possible speed?
Thanks
Unnecessary. Just go ahead and differentiate wrt vb and substitute 0 for ##\frac{dv_c}{dv_b}##.
Likes songoku and Delta2
Thanks
You have completed the proof on the assumption that the three velocities are in the same line.
If not, say C flies off along the y axis. A and B must have equal and opposite velocity components in the x direction. If these are nonzero you can reduce them and spend the saved energy on the y components, keeping momentum conserved and boosting C.
Likes songoku
Sorry I don't understand
Would not this make final momentum in x - direction equals to zero? Hence the momentum is not conserved?
Thanks
songoku said:
Sorry I don't understandWould not this make final momentum in x - direction equals to zero? Hence the momentum is not conserved?
Thanks
sorry, I was assuming that C would be in the original direction and defining that as the Y axis.
Likes songoku
Oh ok
Thank you very much haruspex, delta2 and adesh
Likes Delta2
  • · Replies 53 ·
