Maximum Theoretical Angular Accuracy of Planer arrays
The discussion centers on the angular accuracy of planar and linear sensor arrays, referencing a specific paper that provides equations for accuracy relative to the x and y axes. It highlights that the angle between the incoming ray and the array's normal direction significantly impacts accuracy, with optimal performance occurring at a 90-degree angle. As the angle of incidence deviates from this normal, both angular resolution and signal-to-noise ratio (SNR) deteriorate due to geometric effects and mismatched antenna elements. The relationship between angle and performance is approximated by a rolloff in gain, impacting overall resolution. The key takeaway is that maximum accuracy and resolution are achieved when the incoming ray is aligned with the array's normal direction.
senmeis
Hello,in this link http://dtic.mil/dtic/tr/fulltext/u2/a028054.pdf a paper „Maximum Theoretical Angular Accuracy of Planer and Linear Arrays of Sensors“ can be found.The accuracies are given in equations 19 (respect to the x axis) and 20 (respect to the y axis).My question is: Shall the angle between the incoming ray and the normal direction to the planar array also play a role? I mean, the 90 degrees angle (along the normal direction) shall have the greatest accuracy. In example of line array on page 15 this angle (15 degrees there) is considered. Do I understand it correctly?Senmeis
I haven't read your link, but I can make some general comments about angular resolution. As the angle of incidence moves off of broadside, the apparent extent of the array normal to the incoming wave shrinks by cos(θ), due to simple geometry. This has two effects. First, the angular resolution suffers since it varies inversely proportional to the aperture length. Second, the SNR drops for the same reason. In fact, the electrical gain of the array drops more quickly than cos(θ) because the antenna elements become mismatched (no longer 50 ohms, e.g.) due to varying phase shifts in the mutual antenna coupling terms as the angle increases. It is common to approximate the rolloff in antenna gain (hence SNR) as cos(θ)^1.5, though this is just an approximation. Both of these effects will reduce the resolution and accuracy.
Thank you. Can I understand what you are saying as following in simple words?1. For a planar array the best accuracy and resolution can only be achieved if the incidence ray is on the normal direction.
2. The accuracy and resolution are different with different directions of incidence (different elevation and azimuth angle).Senmeis
I'll need to look at that paper...
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 34 ·
14K
  • · Replies 89 ·
37K
