Maximum value for a analytic function
The discussion revolves around determining the maximum value of the expression |3z^2 - 1| within the closed disk defined by |z| ≤ 1 in the complex plane. Participants explore the properties of analytic functions and the behavior of complex functions on boundaries.
  • Participants discuss the application of the maximum modulus principle and the significance of evaluating the function on the boundary of the disk. There are suggestions to interpret the function geometrically and to consider the exponential form of z on the unit circle.
The conversation is ongoing, with participants providing insights and suggestions for further exploration. Some guidance has been offered regarding geometric interpretations and the implications of the maximum modulus principle, but there is no explicit consensus on the final approach to the problem.
Participants note the complexity of maximizing a modulus in the context of complex functions, questioning assumptions about extreme points and the nature of the function's behavior on the unit circle.
MrGandalf
Hi. I need someone to look at my attempt at a solution, and guide me towards the correct way to solving this. Thanks.
Determine the maximum value of [ilatex]|3z^2 - 1|[/ilatex] in the closed disk [ilatex]|z| \leq 1[/ilatex] in the complex plane. For what values of z does the maximum occur?
The attempt at a solution
There is a theorem that says that all maximum values of an analytic function in a disc occurs at the bound, so the max values will be on some point on the circle [ilatex]|z|=1[/ilatex]. We can easily see that the maximizing points are [ilatex]z = \pm i[/ilatex], and in those cases we get [ilatex]|3(i)^2 - 1| = |-3-1| = |-4| = 4[/ilatex].
It's the modulus that attains the maximum at the boundary, not the function; after all, C isn't ordered, so there is no extreme points for complex valued functions.
Regarding the solution, it's correct, but I think it needs more justification; try to interpret 3z^2 - 1 geometrically, when z is restricted to the unit circle.
It might be helpful to write [tex]z=e^{i\phi}[/tex] on the unit circle...
You might do that, and compute the extreme points (it's not asked but the maximum modulus principle has a counterpart: the minimum modulus principle). But notice that the image of z^2, when z is in the unit circle is a also the unit circle (run over twice); multiplication by 3 will result in a circle with that radius, and -1 is a translation. You should be able to represent graphically the image of 3z^2 - 1, when z is in S1; from that, it's very easy to see where the modulus is maximized (and minimized).
Thanks for all your answers.
I am still not sure how to show mathematically how +/- i will maximize the function.
I tried doing a geometrical approach with drawing a circle with radius 3 and center in -1, but I can't see how it becomes obvious where it is maximized... I also failed to see how looking at the exponential form would help. Maybe I'm still locked in Holiday-mode, but even after all your hints and suggestions I'm still drawing a blank on this one. :)
If you have a circle with radius 3 and centre at -1, what is the point that is farthest from the origin? Will it not be the point with [tex]\theta = \pm\frac{\pi}{4}[/tex]?
Ah, of course! Thanks for explaining this to me.
