Maximum Velocity= 4.8 m/s2Deceleration= -1.2m/s2
  • Thread starter Thread starter alsy
    Velocity
The problem involves a lift that accelerates from rest, travels at a constant velocity, and then decelerates to a stop. Participants are tasked with calculating the maximum velocity and the deceleration during the final phase of the lift's motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of the equation v = u + at to find the maximum velocity and question the application of this formula for calculating deceleration. There are attempts to clarify the meanings of the variables involved.
The discussion is ongoing with various interpretations of the problem being explored. Some participants have provided guidance on the correct application of the equations, while others are still working through their understanding of the concepts involved.
There is confusion regarding the time intervals used for calculations, particularly distinguishing between the time for acceleration and the time for deceleration. Participants are also questioning the initial conditions and the definitions of the variables in the equations.
alsy
a lift accelerates from rest at 1.2m/s2 for 4 seconds..it travels at a constant velocity for 8 seconds and comes to rest in 3 seconds.calculate 1)the maximum velocity 2)deceleration in the final 3 seconds
v=u+at 0+1.2(4) =4.8 m/s2
If you multiply acceleration (m/s2) by time (s), what are the resulting units?
What about the answer to part 2 of this question?
Those are not relevant equations. They are part of the problem statement.
List the equations that you know which might be relevant to the problem you are solving.
v = u +at
I have no deceleration formula
units would be m/s
alsy said:
v = u +at
You're staring at it and you don't realize it.
Think about the information you are given and what you can calculate.
ok
deceleration v = u +at
alsy said:
ok
And ...?
Yes, that's the velocity that the elevator reaches after accelerating.
The elevator takes 3 seconds to come to a stop. What's the deceleration?
v=u+at
8+(1.2)(4)=12.8 m/s
alsy said:
v=u+at
8+(1.2)(4)=12.8 m/s
You're very cryptic in describing what these calculations are supposed to be.
Remember, the elevator accelerates only for the first 4 seconds. After the initial acceleration, the elevator travels at constant velocity for 8 seconds. Does this calculation show that the elevator is traveling at constant velocity?
If velocity is constant, what is the acceleration?
What was that in response to? The last question asked was "The elevator takes 3 seconds to come to a stop. What's the deceleration?" Your answer "12.8 m/s" is not an acceleration. It appears you are answering "If a object has initial speed 8 m/s and accelerates at 1.2 m per second per second for 4 seconds, what is its final speed" but I don't see that question anywhere! You have repeatedly written "v= u+ at". Do you understand what "v", "u", "a", and "t" represent?
4+(1.2)(4)=8.8 m/s
alsy said:
4+(1.2)(4)=8.8 m/s
I'm afraid you've lost the plot and are just typing in random equations here, with little or no understanding of what you are doing.
It's OK to, you know, type in actual words in your reply, to say "I don't understand" or "I need help with this".
v=u+at
I have calculated part one as v=u+at 0+1.2(4) =4.8 m/s
the part 2 deceleration I'm using same formula n
v=u+at and as you say using constant velocity of 4
4+(1.2)(4)=8.8 m/s
that's what I'm getting
Once again, what is that in response to and what are you trying to calculate here? It seems that the only question (of the two you originally asked) was "what is the acceleration and, once again, "8.8 m/s" is NOT an acceleration.
Now you appear to be answering "if an object has initial speed 4 m/s and accelerates at 1.2 m per sec per sec for 4 seconds, what is its final speed", but, again, I see no where that question was asked!
Please, when you post a calculation like this, tell us what you are trying to calculate so we can tell you whether it is correct or not!
alsy said:
v=u+at
4+(1.2)(4)=8.8 m/s
Perhaps you are simply misreading the question.
"u" is the initial speed, "a" is the acceleration (or deceleration if negative), and t is the time the acceleration lasts. In the first part you had u= 0 m/s, a= 1.2 m per sec per sec and t= 8 sec so v= 0 m/s+ (1.2 m/s^2)(4)s= 0+ 4.8 = 4.8 m/s. Yes, that is the correct answer. Now you are just doing the same changing u to 4 m/s?
If you are now doing part b, you are told that it take 3 sec to go back to 0 and are asked to find the acceleration. So now v= 0 m/s, u= 4.8 m/s, and t= 3. So "v= u+ at" becomes 0= 4.8+ a(4). Solve that equation for a.
alsy said:
v=u+at
Why do you say the constant velocity is 4? You just calculated 4.8 m/s in response to the first question.
4+(1.2)(4)=8.8 m/s
The elevator stops in 3 seconds. You have to use 3 seconds when calculating the deceleration.
0= 4.8+ a(4)
0= 4.8 +4A
a=-1.2 m/s
alsy said:
0= 4.8+ a(4)
0= 4.8 +4A
a=-1.2 m/s
Note: 3 seconds ≠ 4 seconds. You're just repeating the same calculation over and over.
0= 4.8+ a(3)
0=4.8 +3a
a=-1.6 m/s
alsy said:
v=u+at
Can you explain in words why you set ##u=0##, ##a = 1.2##, and ##t = 4##?
4 what? Where did this 4 come from?
4+(1.2)(4)=8.8 m/s
Again, can you explain in words why you set ##u=4##, ##a = 1.2##, and ##t=4## here? You need to understand that the variables and equations have meanings, and you can't just plug in a number because it appears somewhere in the problem and has the right units.
The problem statement asks you to find the "deceleration in the final 3 seconds." Don't you think the information that the deceleration took 3 seconds should appear somewhere in your solution? If you're looking for deceleration, what are you solving for — a position, a velocity, or an acceleration?
u=initial velocity
a=acceleration
t=time
8-4=4 constant velocity
alsy said:
0= 4.8+ a(4)
No, 0= 4.8+ a(3). The deceleration back to 0 speed took 3 seconds, not 4
0= 4.8 +4A
a=-1.2 m/s
Solve 0= 4.8+ 3a
(And do NOT switch from "a" to "A".)
0=4.8+3a
a=1.6 m/s
its correct now
a=1.6 m/s
alsy said:
its correct now
a=1.6 m/s
The units are not correct and neither is the algebra you did to solve the equation.
ok
a= -1.6 m/s
alsy said:
ok
a= -1.6 m/s
What are the units of acceleration?
  • · Replies 38 ·
