Meaning of "equatorial radius in an orbital plane"
The discussion centers on the definition of "equatorial radius" within the context of the inverse geodesic problem using the GeographicLib library. The equatorial radius is clarified to refer to the semi-major axis of an ellipsoidal central mass, which is relevant for non-radially symmetric bodies. Participants agree that the equatorial radius is the distance from the center of the ellipsoid, confirming that all points on the equator are equidistant from this center.
  • Understanding of inverse geodesic problems
  • Familiarity with GeographicLib library (version unspecified)
  • Knowledge of ellipsoidal geometry
  • Basic concepts of orbital mechanics
  • Research the implementation of GeographicLib for geodesic calculations
  • Study the properties of ellipsoids in orbital mechanics
  • Learn about the semi-major and semi-minor axes in ellipsoidal models
  • Explore the implications of non-radially symmetric central masses on geodesic calculations
Researchers and engineers working on geodesic calculations, orbital mechanics, and those utilizing GeographicLib for numerical solutions in geospatial contexts.
M.T
I wish to solve the inverse geodesic problem numerically using http://geographiclib.sourceforge.net/html/classGeographicLib_1_1Geodesic.html#a455300c36e6caa70968115416e1573a4, and to finish off I need to specify the "equatorial radius". I am not too familiar with this, and do not see immediately what I would define as "North" or "South" in the orbital plane.
Does the "equatorial radius" here refer to the semi-major axis, or perhaps the apocenter or pericenter?
Hi MT:
I noticed that no one has responded to your question for about a day, so I thought I would try to give a useful reply based on my my limited knowledge.
I do not understand the tool you linked to, so this is just a guess. Perhaps the tool takes into account the possibility that the central mass effecting geodesic calculations is not radially symmetric. In that case the equatorial radius may refer to the maximum radius of an ellipsoidal central mass, like the Earth's equatorial radius is larger than its polar radius.
Hope this helps.
Regards,
Buzz
Buzz Bloom said:
Hi MT:
Hope this helps.
Regards,
Buzz
Hi Buzz Bloom
Thanks for the reply.
The central mass is assumed ellipsoidal, so I agree with you in that it does not have to be radially symmetric. I guess it also makes sense to define the equator along the largest "diameter", that is ##2a ## with ## a ## being the semi-major axis, but is the radius then (1) ## a ## (distance from centre of ellipsoid) or is it (2) ## c+a ## with ## c ## being the distance from the foci where eg. the Earth is; ## c-a ## being the shortest distance between the Earth and the ellipsoid orbit, and ## c+a ## the longest distance.
would I be right then in assuming you mean the distance from the centre (1)?
Thanks,
MT
Hi MT:
Yes, except that no mean is necessary, since for an ellipsoid all points on the equator are equally distant from the center.
Regards,
Buzz
  • · Replies 27 ·
  • · Replies 25 ·
