Meaning of linearly dependent equations
  • Context: Undergrad
  • Thread starter Thread starter 22990atinesh
    Linear equation Linearly
5 replies · 2K views
22990atinesh
How the system of equations
##y=-2x+1##
##y=x+1##
##y=2x+1##
are linearly dependent. In wiki its written for the above system of equations "one equation linearly dependent on the others"
##y=-2x+1##
##y=x+1##
##y=2x+1##
In two dimensions (the plane), there can be at most two linear equations that are linearly independent. Since you have three linear equations, anyone of them can be written as a combination of the others.
It might be easier to think of the equations as a set of three functions: {-2x + 1, x + 1, 2x + 1}.
In this case, I found that -2x + 1 = 4(x + 1) - 3(2x + 1). This is enough to show that the three functions are linearly dependent.
There are at most two vectors in a linearly independent set of two dimensional vectors. But I think we are getting into a technicality about the meaning of "linear independence" of a set of equations . With the equations, I think you must count the constant terms when translating the equations to vectors. For example, I think the equations x + y = 1 and x + y = 2 are considered linearly independent. The definition in http://en.wikipedia.org/wiki/System_of_linear_equations isn't precise, but it implies the interpretation that the constants must be considered because to show dependence you must produce one equation by "algebraic operations" on the others. So the whole equation must be produced, not just the coefficients.
Thanx Mark44, Now I know what mistake I was doing. I always tried to scale one equation and subtract it from other, It always served my purpose.
Hello Mark44 is there any shortcut to find linear dependency among system of linear equations. Scaling one equation then adding/subtracting to other is easy. But when we have to scale both equations and then perform addition/subtraction, It requires little bit of time.
You can write a system of equations as an augmented matrix, and then row-reduce the matrix. What you end up with will tell you whether the equations have no solution, exactly one solution, or an infinite number of solutions. If you are taking a class on linear algebra, you will probably see this soon.
