Measure Theory-Lebesgue Measurable
  • Thread starter Thread starter WannaBe22
    Measurable Measure
5 replies · 3K views
WannaBe22
Let [tex]A \subseteq R[/tex] be a Lebesgue-Measurable set. Prove that if the Lebesgue measure of A is less than infinity , then the function [tex]f(x) = \lambda(A \cap (-\infty,x))[/tex] is continous.
I'm really confused about the definition of [tex]\lambda (A)[/tex] where [tex]\lambda[/tex] is the Lebesgue-measure...I've tried taking an [tex]\epsilon >0[/tex] and choosing some [tex]\delta >0[/tex] for which if [tex]|x-x_0 | < \delta[/tex] then [tex]|f(x)-f(x_0)| <\epsilon[/tex] but I don't think this is the point...
I'll be delighted to get some guidance
Thanks !
Intuitively, [tex]f(x)[/tex] is the measure of the portion of [tex]A[/tex] "left of [tex]x[/tex]". So if [tex]x < x'[/tex], can you interpret [tex]f(x') - f(x)[/tex] in terms of measures?
Intuitively, [tex]f(x')- f(x)[/tex] is measure of the portion of [tex]A[/tex] between [tex]x[/tex] and [tex]x'[/tex] ... Intuitively , this whole thing seems quite trivial...But when I try to get to the formal aspect of the soloution (as seen in "The attempt at a solution" part) , everything messes out... How can I make the intuition more formal ?
I really hope you'll be able to help me
Thanks !
Here are two hints:
1. Given that intuitive description of [tex]f(x') - f(x)[/tex], try to come up with an upper bound for [tex]f(x') - f(x)[/tex] in terms of [tex]x' - x[/tex]. This is what you need to prove continuity. (What property of [tex]A[/tex] would give the largest possible value for [tex]f(x') - f(x)[/tex]?)
2. The fact that [tex]\lambda(A) < \infty[/tex] is irrelevant to the continuity of [tex]f[/tex]; you need it merely to define [tex]f[/tex].
Thanks a lot! your guidance was very helpful!
