Measurement of concentration of urea
Determining the concentration of liquid urea in the range of 0.5-1.5 mol/L can be approached using various laboratory techniques. One suggested method is spectrophotometric determination with diacetyl monoxime, which allows for dilution of the sample before measurement. Concerns about impurities affecting the accuracy of this method were raised, particularly in scenarios where urea is injected into a medium like sand and collected from the other end. The discussion also touched on the challenges of measuring urea in turbid water samples from sandy soil, with inquiries about the potential use of enzymes for dissociation, though this was noted as potentially non-quantitative. Participants encouraged sharing simpler methods for evaluating urea concentrations in such samples.
duke656
Dear All
Does anyone have any idea about how to determine the concentration of liquid urea. The concentration is a bit higher (0.5-1.5 mol/L). Is there any laboratory techniques or Kit? I looked for and found everywhere the method to measure the amount of urea in blood and urea but what I want is in terms of mol/L.
Thanks in advance.
Chemistry news on Phys.org
You can always dilute your sample, use one of the methods for which the procedure is easy to to obtain (perhaps spectrophotometric determination with diacetyl monoxime?), then calculate the concentration in the original sample.
Thank you Borek.
Will this method work if there is some impurities other than urea? For example I will inject 0.5 M urea into one end of a 1 m long tube full of sand. Then I collect samples from the other end and try to evaluate the concentration.
Thanks in advance.
Peace
Deb
duke656 said:
Dear All
Thanks in advance.
You found the method everywhere and you want to know what it is? :confused: Hard to understand what your problem is.
Probably, I could not make you understand. Let me start from the beginning. I have some water samples obtained from the sandy soil. They are a bit turbid and contain urea in higher concentrations (more than 0.5 mol/L). I would like to evaluate the concentrations of only urea of each of these samples. Please share if you know any easier method. Do you suggest me to dissociate it using some enzymes? But it does not sound quantitative is it?
I assume you've read and are familiar with this paper and the references within? Perhaps this one as well?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
