Measurement problem in simple experiment
38 replies · 7K views
msumm21
TL;DR
Trying to better understand the measurement problem in the context of a simple experiment
I’m trying to understand the measurement problem using the simplest experiment I can think of--passing a particle P through a 50/50 beam splitter S, sending it down “path A” or “path B” with equal probability. Each path has a detector that can tell us if P was in that path. The detectors “amplify the signal” to eventually reach our "brain" through a series of interactions. Consider path A. P first interacts with some particle A1, which then interacts with A2, then A3, … until something AN reaches our "brain" to tell us the particle was detected in path A. Likewise in path B: B1,B2,...,BN.
Simple Analysis
P passes S and enters the state A+B before encountering any part of a detector. Upon encountering A1/B1 it becomes entangled in the state ##A\otimes A1 + B\otimes B1## (abusing notation here so that A1 here represents P interacting with the 1st part of the detector in path A). At this point entanglement destroys the pure state of P itself (P itself is in a mixed state, disallowing interference), but the pure state of the larger system remains: interference is possible using the bigger system of P, A1 and B1.
After the next interaction with A2/B2 the state becomes ##A \otimes A1 \otimes A2 + B \otimes B1 \otimes B2 ##. Now P with the first portion of the detectors decohered, but by including the 2nd part of the detectors we could still produce interference between the two alternatives A/B.
Above repeats to A3/B3, A4/B4, ... until we "see a flash" from detector A or B (via AN or BN).
Interpretations / Questions
Decoherence
Some people reportedly believe decoherence solves the measurement problem. In the context of this experiment, do some believe that decoherence of P after interacting with the first portion of the measuring device constitutes collapse? If so, how do they explain the interference that can occur in the larger system P,A1,B1? If not, how do they mark a particular step where collapse occurred?
Pilot-wave theory
If, at any time in this experiment, interference between the two paths can be created, then when & how do you reveal which path P actually went down? When does the pilot wave "disappear" from the path that doesn't contain P?
Any other interesting interpretations or points about this experiment?
"Some people reportedly believe" is not a valid reference. You need to give a reference to an actual valid source (textbook or peer-reviewed paper) where this claim is made.
Once decoherence has happened, interference can't be created between the two paths any more.
Never. The pilot wave doesn't "collapse" in the pilot wave interpretation.
They are wrong. Like Chris Gerry is wrong in his book, "The Quantum Divide" (published by OUP), that the cat is either dead or alive as a result of quantum decoherence (see pages 162 - 164).
After P interacts with A1/B1, the state of P itself is mixed, but the more complete system of P, A1 and B1 is pure until it interacts with A2/B2, so interference can occur, right? For example see operation A in this post which apparently introduces interference after "Wigner's friend" measures a qubit.
If the total number of degrees of freedom is small enough in A2/B2 that they can all be tracked, yes. But at some point in the chain that will no longer be true; for some N, the interaction with AN/BN will spread among a number of degrees of freedom that is too large for them all to be tracked. That is when decoherence occurs. And N is going to be well before the interaction spreads to the point of including an observer's brain. A macroscopic photon detector by itself has enough degrees of freedom.
Such claims are hand-waving, without any actual math to back them up. Basically, "Wigner's friend" in such thought experiments is treated as though he were a qubit himself, instead of a human being with a human brain and human sensory system that has some ##10^{28}## or more degrees of freedom. (Not to mention that even the measuring device he uses to measure the qubit will have enough degrees of freedom to decohere before the interaction even gets to his brain and sensory system.)
For simplicity let me take a qubit 0+1. What I'd thought was that decoherence occurred when it interacted with anything X so that the resulting states of X were orthogonal, i.e. system state ##0\otimes X_0 + 1\otimes X_1## where ## X_0 \bot X_1##. So that decoherence may occur with the subsystem (qubit) but never in the larger system including all things that have been interacted with. If true, there's never decoherence in the full system, it's only a property of subsystems. I realize that, in practice, things may get overwhelmingly complicated quick, but I'm aiming for what happens in quantum theory.
Was that in Her Brittanic Majesty's Christmas message?
No, that's not nearly enough. ##X## could just be another qubit, set up to interact with the first so that, for example, they end up in an entangled state with total spin zero. Such an interaction could easily be reversed (in fact such interactions and reversals between qubits are commonplace in quantum computing).
No. I have no idea where you're getting this from. The whole point of decoherence is that it happens because of interactions spreading among "the larger system including all things that have been interacted with", because as the number of things (more precisely, degrees of freedom) interacted with continues to increase, it becomes impossible to keep track of all of them.
Again, I have no idea where you're getting this from. It's wrong. See above.
PeterDonis said:
No, that's not nearly enough. X could just be another qubit, set up to interact with the first so that, for example, they end up in an entangled state with total spin zero. Such an interaction could easily be reversed (in fact such interactions and reversals between qubits are commonplace in quantum computing)
In the case of two qubits that become entangled to the singlet the density matrix of either one is diagonal, a mixed state, right? When the density matrix of a system becomes diagonal by interaction with another, is this not referred to as decoherence? If not, when do we call it decoherence? As far as I know it's just a repeat of the same logic whether the interaction is with 2, 3, 4, or 10^10 other particles--in all cases the density matrix of the qubit becomes diagonal iff the state can be written ##0\otimes E_0 + 1\otimes E_1## where ##E_0 \bot E_1##.
For each qubit taken individually, yes.
No.
I already answered that. Go back and read my previous post again, carefully.
No, it isn't. You are looking at the wrong thing. Go back and read my previous post again, carefully.
As far as the density matrix is concerned, when the literature on decoherence talks about off diagonal terms in the density matrix disappearing, they are not talking about the reduced density matrix of an individual subsystem. They are talking about the density matrix of the combined system; the disappearance of off diagonal terms means the elimination of the possibility of interference between the different alternative configurations of the combined system.
Cheeky!
This decoherence takes place in Hilbert place, where the state vectors of QM resides, right? And thus has nothing to do with an environment.
We are always talking about reduced matrices right, neither of us is referring the entire universe? If we were, there always would be the ability to create interference, right?
On the original question, I guess I'm getting the feeling there's no answer to "where" decoherence occurred in the chain of events A1, A2, ... It's just a subjective thing?
Yes.
No. The Hilbert space in question includes the degrees of freedom contained in the environment. That's the whole point.
Not if we're talking about decoherence.
Not once decoherence has taken place.
No. It occurs when I said it would in previous posts. Go read them.
Are you talking about the quote below? Neither here nor anywhere else do I see a precise definition of when decoherence occurs (my question in the OP). Don't you agree the quote below is subjective? Or if you have a precise definition of "number of degrees of freedom that is too large to track" could you provide it?
That is the measurement problem!
Yes.
No. The fact that there is no cookie cutter procedure for determining exactly how many degrees of freedom is "too many to track" does not mean it's subjective. There is plenty of literature on experiments that measure decoherence happening. The deficiency is in our theory: we don't have a good theoretical way of predicting in advance exactly when decoherence will happen in a given case. In other words, we have a lot more to learn. But that doesn't make what we have a lot more to learn about subjective.
No, it isn't. The measurement problem is the problem of why we only observe a single result, even though the math, including the math of decoherence, does not show a single result; it shows multiple "branches", one for each possible result, which don't interfere with each other once decoherence has happened. Having a theory that told us in detail, in every case, exactly when decoherence would happen, i.e., how many degrees of freedom were "too many to track" in that case, would still not solve the problem of why we only observe a single result.
Just to be clear, these experiments are finding processes that eliminate interference? Deviating from QT? OR do you mean something else?
We can't predict because QT implies something different or because we just can't do the math accurately enough with all the DOF, ...?
Thanks
They're measuring decoherence. They can't measure the individual interactions that cause decoherence, because if they could, it wouldn't be decoherence; the whole point of decoherence is that you can no longer track the individual interactions with the environment.
No.
Yes.
PeterDonis said:
No, that's not nearly enough. X could just be another qubit, set up to interact with the first so that, for example, they end up in an entangled state with total spin zero. Such an interaction could easily be reversed (in fact such interactions and reversals between qubits are commonplace in quantum computing).
This doesn't seem consistent with e.g. "Theory of Decoherence" (section 1) explanation here. They use the example of an electron double-slit experiment, and claim decoherence occurs if the electron interacts with something at the slits that suppresses interference. They even point out that interference is still possible in the "larger system," and decoherence is merely a property of looking only at the subsystem of the electron.
This is a philosophy website, not a physics textbook or peer-reviewed paper. See further comments on that below.
By that they mean (though they don't say so--see my comment below about philosophy websites and physics) "something at the slits that entangles the electron with a large number of degrees of freedom that cannot be kept track of". That's what "suppresses interference", by which they mean "results in no interference pattern being observed".
And what you are failing to recognize (and the article does not make it clear, which is why articles on a philosophy website are not good sources for learning physics) is that there is no way to do the relevant experiments on the "larger system", because the large number of degrees of freedom involved cannot be kept track of. (This is also a common omission in discussions of "Wigner's friend" type experiments, where it is often blithely assumed that one can treat human beings as if they were single qubits to which arbitrary unitary operations can be applied.) If in a particular scenario you can do the relevant experiments on the larger system to show interference, then decoherence has not yet occurred.
Not sure what they meant, but suppression of an interference pattern on the screen only requires e.g. qubits to mark the slot through which the electron passed (not a large, untrackable DOF).
Here's another reference:
Decoherence, the measurement problem, and interpretations of quantum mechanics
On page 7 I read:
"Environment-induced decoherence. The fast local suppression of interference between different states of the system. However, since only unitary time evolution is employed, global phase coherence is not actually destroyed—it becomes absent from the local density matrix that describes the system alone, but remains fully present in the total system-environment composition."
Can you describe a specific experimental setup in which that statement is true?
Wrong. It requires some kind of irreversible interaction at the slits. A simple interaction with a qubit is not irreversible; you could track the qubit and reverse its effect and make the interference pattern re-appear.
If, OTOH, you measured the qubit in order to see which slit the electron passed through, then the interaction is not just with the qubit; you have a large number of untrackable degrees of freedom in the measuring device you're using to measure the qubit. That would be an irreversible interaction and would make the interference pattern disappear and not be recoverable. (Note that this "measurement" would not have to be observed by a human; just having the qubit interact with a macroscopic measuring device, even if its result were thrown away, would be enough.)
Yes, but this "global phase coherence" cannot be used to reverse any interactions or undo any measurement results. That's the key criterion. The "only unitary time evolution is employed" is why decoherence does not solve the measurement problem. It doesn't mean decoherence is just the same as two qubits getting entangled.
[About whether interference is possible]
Just for clarification, this is a “for all practical purposes” type claim, right? The full density matrix never actually evolves to be diagonal, it’s just that the off-diagonal terms become too small to be of any practical relevance. Interference between macroscopically distinguishable states is impossible for all practical purposes in a similar sense that fixing a broken egg by shaking the pieces is impossible. It’s not mathematically impossible, but so unlikely that it’s practically impossible.
That depends on which QM interpretation you adopt. In a no collapse interpretation, yes. In a collapse interpretation, no.
As I understand the basic math of decoherence, yes, that is all you can conclude. The rest is a matter of interpretation, as above.
This is not correct, once the slit has been marked by an interaction, the interference pattern at the screen will not occur. Of course you can always reverse this in QT (unitary transformation are reversible), but I didn't say "mark it and then erase it."
