Mechanical Principles help please.
The discussion revolves around calculating the effort required to raise a load using a Weston differential pulley block, including considerations of efficiency and work done against friction. Participants explore the necessary formulas and clarify terms related to the problem.
  • Homework-related, Technical explanation
  • One participant, Joe, presents an initial calculation for the effort and work done, questioning the correctness of their units and approach.
  • Another participant suggests using specific formulas for velocity ratio and mechanical advantage, indicating that they have encountered similar problems in class.
  • There is a clarification about the meaning of "d" in the formulas, with one participant confirming it refers to diameter.
  • Joe expresses confusion about whether to use diameter or circumference in calculations, indicating a potential misunderstanding of the problem setup.
  • Another participant asserts that using diameters yielded correct answers in their calculations, suggesting consistency in their approach.
Participants do not reach a consensus on whether to use diameter or circumference in the calculations, indicating a point of confusion. The discussion remains unresolved regarding the correctness of Joe's initial calculations.
There are unresolved assumptions regarding the definitions of terms and the application of formulas, particularly concerning the use of diameter versus circumference in the context of the pulley system.
crutts
1. The top pulleys of a Weston differential pulley block have diameters of 210mm and 190mm. Determine the effort required to raise a load of 150kg if the efficency of the system is 35%.
What is the work done in overcoming friction when the load is raised through a height of 2.5m?
I did some working out and got:
effort = load/number of pulleys = 150/2 = 75 (what units?)
and work done= (150x9.8) x 2.5 = 3677.6 N/M
I did 150x9.8 to get Newtons.
Is this correct?
Cheers Joe
you must work out using these formulas
i only no this as i did the same question in class
you need to work out the velocity ratio of the machine first
vr = 2 d1/(d1-d2)
then the mechanical advantage
effiency of the system = mechanical advantage/ velocity ratio x 100 %
you need to transpose this
effort of the machine = load / mechanical advantage
this is for the first part
second part is
wd = force x distance moved
then effiency of the system = work output/work input
you also need to transpose this
i no how you feel this is a hard subject and i am also finding it hard !
I take it d stands for diameter? Should it be this or should it be circumfrence?
Joe
d is the diameter of each pulley
Should I use diameter or circumfrence? As i seem to remember circumfrence being mentioned in class.
when i calculated these i used the diameters and the answers were correct compared to the answers i had.
Ok cheers.
10K
  • · Replies 27 ·
11K
9K
