Mechanical problem -- a mass sliding down a curved ramp
14 replies · 5K views
PeppaPig
An object which has mass = m is released from point A which has height of h. The object moves along the rail with no friction. The rail OB is a semicircular rail which C is the center and R is the radius. If the object falls from the rail at the point B, find the following.
1) h/R
2) Distance of the object from point O if the object lands on the surface without hitting the rail
Using the law of energy conservation
mgh + 1/2mv2 = mgh + 1/2mv2
The object should have velocity of sqrt(2gh) at point O
What should I do next at the semicircular rail?
How to calculate the reaction from the rail since the object will fall if the reaction is 0?
What speed must the object have at B to just start leaving the track at that point?
The vertical speed is 0?
I haven't studied the centripetal force yet. Is it used in the calculation?
What's the horizontal speed?
Yes. To figure out the minimum speed it must have to just barely make it to point B, you must consider centripetal force & acceleration.
FYI: If the object isn't moving fast enough, it will leave the track before getting to point B.
I just read about the centripetal force on wikipedia. The formula is F = mv2/R which v2/R is the centripetal acceleration.
How can I use this to solve this problem?
Good. Your textbook should have plenty of examples to learn from as well.
Apply Newton's 2nd law at point B. What forces act?
Doc Al said:
Good. Your textbook should have plenty of examples to learn from as well.Apply Newton's 2nd law at point B. What forces act?
There are the gravitational force and centripetal force which are mg and mv2/R. Reaction force = 0 means the centripetal force (from object to center) is equal to gravitational force. Is that correct?
Good! Now set up an equation to solve for the speed/energy needed at that point.
I have another question. v at point B is equal to v and point O?
Why would you think that? Energy is conserved! (Those points are at different heights.)
Oh! I forgot about that.
1/2m(2gh) = 1/2mv2 + mg(2R)
v2 = 2g(h - 2R)
Then mg = mv2/R
g = (2g(h-2R))/R
h/R = 5/2
Then use v at point B to calculate distance from O after landing using projectile. Is that correct?
PeppaPig said:
h/R = 5/2
Good!
Exactly.
Doc Al said:
Good!Exactly.
Thank you very much.
Yes but that's not quite the way I would think about it. The two forces aren't gravity and the centripetal force. The two forces are gravity and the normal force from the track.
In order to move in a circle something must provide a net centripetal force = mv^2/, no more and no less. In this case the two forces that combine to produce the centripetal force are gravity and the normal force produced by the track. The normal force originates from the inertia of the object which tries to make it move in a straight line.
If gravity provides less than mv^2/r then the normal force from the track will provide the rest.
If gravity provides more than mv^2/r the radius will reduce and it will fall down.
