Mechanical seal monitoring system ?
The discussion focuses on the operation and monitoring of a mechanical seal cooling system used with a blower for nitrogen cooling. Key concerns include the implications of using a smaller pump with lower head pressure and the potential replacement of a flow meter and pressure switch with a flow control valve. Participants highlight the importance of maintaining a zero differential pressure (dP) across the seal and ensuring adequate coolant flow for effective cooling. Suggestions include using a pressure regulator for controlling nitrogen pressure and exploring alternative methods for monitoring seal performance. The conversation emphasizes the need for efficient cooling and monitoring solutions in mechanical seal applications.
maxx_payne
mechanical seal monitoring system ?
hello everyone
i have a system consists of A blower used for nitrogen cooling
this blower has a mechanical seal which is cartidge seal and the seal cooling liquid is water
pumped from a water tank via a water pump to keep both surfuces of the seal blanced under 10 bars each one face is for water and the other is for nitrogen the questions is ?
1- what will happen if i run the seal with smaller pump which has smaller head than the big pump?
2- the mechanical seal cooling system contains a flow meter " safe unit " john crane this flow meter has a pressure switch to ensure that the blower is running only if the cooling pump is working an realized its pressure so
what if i replaced this safe unit with a flow control valve with a normal pressure switch ?
Hi maxx. Why do you need the 0 psi dP across the seal when it's running? As I understand it, you have the 10 bar nitrogen on the one side and 10 bar water on the other side of the seal for cooling. Is that right? Does the seal get that hot that you need a coolant? Do you need the water pressure to be the same as the nitrogen pressure or do you just need the right cooling water flow rate?
I've seen plenty of seals that need close to 0 dP and they generally use a pressure switch, but if your seal needs cooling water flow, then maybe both are necessary.
YES I NEED THE DP =0
THE main problem is if i don't have the monitoring system which is the flow meter with the pressure switch can i replace this manually and what if i need the correct flow rate of coolant of the seal ?
Do you have the nitrogen at high enough pressure available? John Crane uses many setups with supplied nitrogen and needle valves for simple flow control.
I would imagine there's a reason that a blower was used as opposed to a very cheap and simple needle valve/regulated nitrogen setup.
Do you just want to control the pressure or do you want to try and control the flow (really on seals you'd more likely monitor the flow to see changes in seal leakage). If you just want to control the pressure and have pressurized nitrogen available without the blower you can use a pressure regulator. If the cooling water pressure may change then you can reference the regulator to it.
can u send me some technical notes on mechanical seals ?? i want to be proffissional with this
well i have a new idea of removing the flow meter and pressure switch also and use
nitrogen from the blower outlet to pressurize the cooling fluid
is this will be effiecinet
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
