Mechanical vibrations: colliding blocks
2 replies · 1K views · last reply
vxr
One block of mass ##m = 0.20 kg## traveling at velocity ##v = 5 m/s## collides elastically with a second block of mass ##M = 0.80 kg## resting on a frictionless surface and connected to a spring with elastic force constant ##k = 80 N/m##.
What is the angular velocity ##\omega##, period ##T##, and the amplitude ##A## of block’s oscillations? Determine the respective values for the case when damping effects will appear with overall damping coefficient ##\beta = 21/s##.
##\omega = \sqrt{\omega_{0}^2 - \beta^2}##
I saw this general formula:
##w_{0} = \sqrt{\frac{k}{m}}##
In my case both masses after collision create connected system, so ##w_{0} = \sqrt{\frac{k}{m+M}}##
Plugging it into ##\omega = \sqrt{\omega_{0}^2 - \beta^2}## gives :
##\omega = \sqrt{\frac{k}{m+M} - \beta^2} = \sqrt{80 - 21^2} < 0##
It's a root of negative value. Why is that happening? Am I doing something wrong, or perhaps the damping coefficient is relatively too large in this task?
One more question: I know how to calculate the period ##T##, but what about amplitude ##A##? Is it simply: ##A = A_{0}e^{-\beta t} \quad \land \quad A_{0} = 0 \Longrightarrow A = 0##? If this is the case, why is this ##A_{0} = 0## true?
The statement "collides elastically" usually means that the masses separate after the collision, not that they stick together. Treat the collision as occurring instantaneously with momentum and kinetic energy being conserved to find an expression for the velocity of the mass connected to the spring immediately after the collision.
@kuruman is right that you should only have used the mass attached to the spring, but that is not the explanation for the negative value. Clearly you could change the question to make it a coalescing collision.
The value is negative when it is an underdamped oscillation. See
http://hyperphysics.phy-astr.gsu.edu/hbase/oscda.html
