Mechanics: Angular Velocity Vector Questions
The discussion focuses on calculating angular velocity and velocity vectors in a helical motion scenario. Key points include the use of the position vector to derive velocity through differentiation, with the specific formula provided for the position vector. The conversation emphasizes that rotational formulas are unnecessary for this problem, as basic calculus suffices. Participants also touch on the relationship between linear velocity and angular velocity in circular motion, but suggest avoiding unnecessary complexity. The thread concludes with a confirmation that the provided information is helpful for understanding the problem.
girlwhoneedsmathhelp
The question :
The position vector of a rider on a helter-skelter is given by : r = (2sin t)i + (2cos t)j + (8-1/2 t)k where the units are in metres and seconds. The unit vector k acts vertically upwards.
(I) Find an expression for the velocity of the rider at time t
(ii) Find the speed of the rider at time t
(iii) Find the magnitude and direction of the rider's acceleration when t = pi/4
From the first part I am very confused on how to figure this out. I know that this question has to relate with the formula for v =wr, but I am unsure how to approach it. Even after looking at the answers for I, I still do not know how to do ii and even less for iii.
v=wr
Answers are the following :
(i) v=(2cost)i - (2sint)j -(1/2)k
(ii)2.06m/s
(iii)2m/s^2 horizontally towards the vertical axis, making an angle of pi/4 with both the I and j axes.
You don't need any rotational formulae. You have$$\vec{r} = 2\sin{(t)} \hat{i} + 2\cos{(t)} \hat{j} + (8-\frac{1}{2}t)\hat{k}$$The velocity is ##\vec{v} = \frac{d\vec{r}}{dt}##, i.e. the time derivative of the above. Does that help you get started?
Likes girlwhoneedsmathhelp, gurbir_s_sidhu, Adesh and 1 other person
Okay, let us know why you think we have to use ##v= \omega r## formula, it's always better to talk. We from basic mechanics know two things:
1. Derivative of position is the velocity.
2. In a circular motion linear velocity, radius and angular velocity are related by ##v =\omega r##.
Let me know what are your thoughts on them and their relation to your original question.
Likes etotheipi
@Adesh It is a good comment but it is heading slightly off topic. I will answer it for the OP: ##\vec{v} = \vec{\omega} \times \vec{r}## pertains to a circular velocity field about a point, e.g. the velocity of a point on a rigid body w.r.t. another point on the rigid body, or the velocity of a particle undergoing circular motion. To digress, it's not totally irrelevant here because we are dealing with helical motion, so we could perform a Galilean boost to a frame where ##v_z = 0## and we would end up with circular motion with ##\omega = 1##.
But this question is almost certainly just an exercise in calculus. So let us please first hear back from the OP.
etotheipi said:
##\vec{v}=\vec{ω}\times \vec{r}## pertains to a circular velocity field about a point, i.e. the velocity of a point on a rigid body w.r.t. another point on the rigid body, or the velocity of a particle undergoing circular motion.
As the question is about a single body which is considered as a point body so we can just use the formula ##v=\omega r## for any instantaneous circular path.
etotheipi said:
To digress, it's not totally irrelevant here because we are dealing with helical motion, so we could perform a Galilean boost to a frame where ##v_z=0## and we would end up with circular motion with ω=1.
But how would you get ##\omega##? I know we will get a helix of radius ##2## (I mean projection of helix on the ##xy## plane will result in a circle of radius 2), but to get ##\omega## you have to have ##v## which you will get only by differentiating the the expression for position.
You can do something like this, but it is yet another added degree of complexity to what is really a very simple problem. What you are suggesting is to use an intrinsic coordinate system with basis ##\{ \vec{e}_n, \vec{e}_t, \vec{e}_b \}##, and you are using the fact that in intrinsic coordinates$$\vec{v} = v\vec{e}_t$$and$$\vec{a} = \dot{v} \vec{e}_t + \frac{v^2}{\rho} \vec{e}_n$$and it may well be convenient to define a parameter ##\omega##, given the cyclical nature of the helical motion, s.t. ##v =\rho \omega##, if ##\rho## is the instantaneous radius of curvature (which you also need to go and work out from the equation of the helix!). But I do not suggest this for the OP, it is a billion times harder than necessary.
If you performed the Galilean boost, ##\omega = 1##. That will allow you to find the ##x## and ##y## components of the velocity in the original frame, if you so wished.
But again, added complexity to just ##\frac{d}{dt}##ing the original expression. I think it is best now that the OP replies to post #2.
Yes, thanks a lot!
Likes etotheipi
  • · Replies 17 ·
