Mechanics- connected particles
12 replies · 2K views · last reply
Shah 72
MHB
Two smooth pulleys are 8m apart at the same horizontal level. A light inextensible rope passes over the pulleys and a box of mass 5kg hangs at each end of the rope. A third box of mass m kg is attached to the midpoint of the rope and hangs between the pulleys so that all the three boxes are at the same horizontal
Diagram of a rope over two pulleys with a box hanging from each end and a third box hanging from the middle of the rope, with the two pulley spans each labelled 4 m.
level. The total length of the box is 16m. Find the value of m
total length of the box? … maybe the string length is 16 m ?
if so, I get m = 7.5 kg
Iam so so sorry again typo error. Its the total length of the rope = 16m
The ans in the textbook says 6 kg.
Can you pls pls tell me how to work it out?
6 kg is correct … I used the wrong value for a trig ratio.
Can you pls pls tell me the method you worked it out? I have no clue how to solve it.
skeeter said:
$h + \sqrt{h^2+16} = 8$
By squaring both sides I will get 2h^2=-8 .
$\sqrt{h^2+16} = 8-h$
square both sides …
$h^2+16 = 64 - 16h + h^2$
$16h = 48$
$h =3$
check solution …
$3 + \sqrt{3^2+16} = 3 + 5 = 8$
checks good.
recommend you review solving radical equations …
square both sides …
$16h = 48$
$h =3$
check solution …
checks good.
Thank you so so much! None of these things are explained in the textbook. Iam really struggling with the pulley and string questions. I will surely look into solving radical equations.
