Mechanism that causes tension and normal force?
The discussion centers on the mechanisms that cause tension in materials like rubber bands and the normal forces exerted by structures such as walls and tables. Key insights include the role of material elasticity and the fundamental forces that maintain structural integrity under applied loads. The conversation highlights that while elasticity affects how much a material stretches, the tension developed is directly related to the magnitude of the applied force. Additionally, the discussion touches on the atomic bonds that contribute to a material's ability to resist breaking under tension.
  • Understanding of material elasticity and its effects on tension
  • Familiarity with atomic bonding concepts in materials science
  • Basic knowledge of forces, including tension and normal force
  • Introductory physics concepts related to structural integrity
  • Research the principles of material elasticity and its mathematical representation
  • Study atomic bonding types and their impact on material strength
  • Explore the concepts of tension and compression in structural engineering
  • Learn about the Pauli exclusion principle and its relevance to material properties
This discussion is beneficial for first-year physics students, materials scientists, and anyone interested in understanding the mechanical properties of materials under stress.
InertialRef
What is a mechanism that might cause a rubber band or a string to develop tension in response to a force that you apply?
What mechanism explains how walls and tables exert normal forces without bending noticeably?
None, since this is a conceptual question.
I initially wrote down the elasticity of the material used for the rubber band as well as the wall. However, I'm not completely sure my reasoning is correct. Elasticity only affects how much the object would stretch when a force is applied, not the tension force that is developed in response. Even if you had two rubber bands, one more stiffer than the other, if you applied the same amount of force on them, wouldn't they exert the same amount of tension back? In that case then, wouldn't it be the magnitude of the force exerted upon the rubber band or wall that is the mechanism?
I think they are asking for a deeper explanation. For example what stops a rubber band (or anything else) simply falling apart when a force is applied? What keeps the material together?
I'm not completely sure about that, since it's a first year physics course. But if they were asking for a deeper explanation, wouldn't that involve discussing the types of bonds that make up the material?
May not need to explain the different type of bonds, just that bonds are involved?
The question about walls and tables asks why they don't bend so perhaps this is also a question about tension rather than compression? Otherwise for compression I think you have to talk about the Pauli exclusion principle? But have you covered that yet?
