How Does Angular Momentum Affect Merry-Go-Round Speed?
  • Thread starter Thread starter makeAwish
    Physics
The discussion revolves around a problem involving a merry-go-round with a specified radius and moment of inertia, where a child applies a tangential force. The objective is to determine the angular speed after a certain time interval, considering the effects of angular momentum and external forces.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the application of angular momentum conservation and question whether the child’s force is considered external. There is discussion about using torque and angular acceleration to solve the problem. Some participants suggest treating the problem similarly to linear motion equations.
Participants have provided various insights into the problem, including the need to calculate torque and angular acceleration. There is an acknowledgment that the child is not on the merry-go-round, which affects the conservation of angular momentum. Some guidance has been offered regarding the use of kinematic relationships for finding angular displacement.
There are indications that the child’s weight is not provided, which may affect the interpretation of forces involved. The discussion also highlights the need to account for angular acceleration when calculating work done, as the angular speed is not constant.
makeAwish
A playground merry-go-round has radius 2.00m and moment of inertia 3000kgm² about a vertical axle through its center, and it turns with negligible friction.
A child applies an 18.0N force tangentially to the edge of the merry-go-round for 25.0s . If the merry-go-round is initially at rest, what is its angular speed after this 25.0s interval?
The attempt at a solution
I have no idea what to apply actually. I only thinking of treating the child as a particle.
Moment of inertia of child = mr²
Can apply consv of angular momentum? But is the child considered to be acting external force?
Can someone help me pls? Thanks!
Based on what you wrote, it sounds like the child isn't actually on the merry-go-round (especially since the child's weight is not given) so I would assume the child's push is simply an external force.
I'd think you could use torque/angular acceleration or angular impulse/momentum to solve
The child isn't riding the merry-go-round, she's just exerting an external force on it. Angular momentum is not conserved. What torque does she exert? Apply Newton's 2nd law for rotation.
The child is not on the merry-go-round so it does not make sense to calcuate his/her moment of inertia. This question is analogous to applying a force to a mass and asking how fast it would go after a given time. You would use F = ma to find the acceleration and then use v = at to find the velocity. In the merry-go-round problem, use the analogous circular motion formulas.
F = ma ---> Torque = I\omega
v = vi + at ----> \omega = \omega i + \alpha t
Okay, i got it. thanks! angular speed = 0.3rad/s
The next part is actually:
How much work did the child do on the merry-go-round?
I tried working out.
W = Fs = Frθ = Fr(integration of ω) = 18*2*0.3*25 = 270J
But its wrong..
It's wrong because the angular speed is not constant, so θ ≠ ωt. Use your kinematic formulas to find the angle.
Write the torque equation and find out angular acceleration.
Use it to find the angular velocity after a certain period of time. (Use kinematic relationship)
But its wrong..
The angle through which it has rotated can be found out by kinematics again. :wink:
The angle won't be of the form \theta = \omega t cause there is acceleration.
