Mesh Tally in MCNPX for Dose Calculation / How to Add & Visualize?
  • Thread starter Thread starter Ayb_mcnp
The discussion focuses on implementing mesh tallies in MCNPX for calculating and visualizing photon dose distributions. The user seeks guidance on correctly inserting the mesh tally block into their input file, running the tally using the MCNPX Visual Editor, and visualizing the results. The specific syntax for the dose mesh tally is provided, indicating the use of TMESH and RMESH1 commands. This inquiry highlights the transition from standard tallies like F4 and F5 to mesh tallies, emphasizing the need for precise input formatting and visualization techniques.
  • Familiarity with MCNPX 2.7.0 or later
  • Understanding of standard tallies such as F4 and F5
  • Knowledge of mesh tally syntax and structure
  • Experience with MCNPX Visual Editor for input file management
  • Research the detailed syntax for TMESH and RMESH commands in MCNPX documentation
  • Learn how to configure and run mesh tallies in MCNPX Visual Editor
  • Explore methods for visualizing dose distribution results from mesh tallies
  • Investigate troubleshooting common issues with mesh tally inputs in MCNPX
This discussion is beneficial for medical physicists, radiation safety professionals, and researchers utilizing MCNPX for dose calculations and visualization in complex geometries.
Ayb_mcnp
TL;DR
I'm using MCNPX Visual Editor X_2SS and trying to add a mesh tally (RMESH1:p dose) for photon dose distribution.
I get an error when I add the mesh tally block. I need help on:
- How to properly insert the mesh tally in my input file.
- How to run it using the Visual Editor.
- How to extract and plot the dose results after the simulation
Hi everyone,
I'm currently working with MCNPX and I'm trying to apply a mesh tally to calculate and visualize the photon dose distribution in my geometry.
I have experience using standard tallies like F4 and F5, but this is my first time working with mesh tallies. From the documentation, I understand that MCNPX allows the following syntax for dose mesh tallies:
TMESH
RMESH1:p dose
CORA1 0 10i 400.0
CORB1 0 10i 400.0
CORC1 0 5i 150.0
ENDMD
I’m using MCNPX Visual Editor.
What I Need Help With:​
  1. How can I correctly insert the mesh tally block into my input file so that MCNPX Visual Editor accepts it?
  2. How do I properly run this mesh tally using the Visual Editor?
  3. After running the mesh tally, how can I visualize the results?
Any help, tips, or examples would be greatly appreciated.
Thank you in Advance.
