Method of storing energy on the Moon
Flywheel energy storage is a superior alternative to batteries for lunar applications due to the Moon's vacuum environment, reduced gravity (1/6 Earth gravity), and naturally low temperatures suitable for superconductors. Flywheels offer higher durability and energy density, with claims of up to 1000 Wh/kg, outperforming batteries in lifespan and weight efficiency. Thermal cycling remains a critical challenge for both flywheels and batteries, but underground or insulated installations, along with sunshades or lava tubes, can mitigate these effects. Local manufacturing of components like spun basalt fiber is a long-term goal but initial flywheel systems will rely on Earth-supplied parts. Batteries require significant thermal management and modular shipping advantages but degrade faster over time compared to flywheels.
  • Superconducting magnetic suspension technology
  • Thermal cycling effects on motor/generators and batteries
  • In-situ resource utilization (ISRU) for lunar manufacturing, specifically basalt fiber production
  • Energy storage system mass and cost estimation for lunar deployment
  • Research advanced flywheel design with superconducting magnetic bearings for lunar conditions
  • Study thermal insulation techniques such as rock wool blankets and sunshade deployment on the Moon
  • Analyze cost-benefit and mass trade-offs between modular battery systems and flywheel energy storage
  • Investigate lunar basalt fiber manufacturing processes and their feasibility for structural components
Space engineers, lunar habitat designers, energy storage researchers, and mission planners focused on sustainable long-duration lunar bases and extraterrestrial manufacturing infrastructure development.
  • #31
If I were to try and create a system which guarantees power for a moon-base, I would look at building a rail system around the moon on which to transport solar panels.
The moon has an equatorial circumference of 10917km, and rotates once every 29.5 days, which equates to just under 15.5km/h, to have a carriage running around the equator and staying in the centre of daytime. There are over a million miles of train tracks on earth, so 11,000km (just under 7000 miles) is not an unachievable distance, especially if it can be made out of local materials. Alternatively, a road could be flattened on the surface, to give it something to run on which is relatively flat, and the panels could just roll on all-terrain tyres.
It wouldn't be difficult for a solar panel vehicle to power itself to 15.5km/h and still have energy to spare, especially on rails (As momentum would be constant, it only needs to overcome resistance once it's to speed - maglev would be ideal, but unlikely to come from local materials!)
Have the rail system able to send power back (like a model train in reverse) and the stationary colony can have power all day and all night without needing to store it.
(this would also be a good premise for sci-fi!)
  • #32
That's a clever idea, but you would probably need to build in some sort of redundancy and repair capability in order to deal with meteorite damage. Perhaps two parallel tracks separated by 50m or so, and the ability for each to power repair vehicles on the other track. That way when one track is damaged and that solar panel train/vehicle stalls, the repair vehicles can still get power from the other track.
I have no idea what the probabilities are for meteor impacts of different sizes versus time on the Moon, but I'm sure there are some papers that describe those probabilities.
https://www.google.com/search?q=moo...UZGJLMDhjUFN1Y00YADABGAcgyuLO-w9KCBABGAEgASgB
  • #33
I believe that the moon doesn't get hit that often, I think (and I could be wrong) that it just doesn't have any way to recover from impact - no weather to erode, no life to grow. So we're seeing a complete history of when the moon got hit by rocks.
If there were significant risk of meteoric impacts, I would instead go for making a road system and having automated vehicles to follow it. Not sure how the power could be transferred though - maybe a cable system like trams use.
If the road were damaged, the solar vehicles could go around it using off-road capabilities, and then reconnect. Meteor damage to the cables might be a risk, but I don't know how much of one!
  • #34
I suspect 2 tilt tracking solar farms on high ground (or 3 fixed) and cabling would require less materials, equipment, construction and maintenance than a railway. Very uneven terrrain, a lot of going around craters and boulder fields.
Cabling that long and able to work in the extremes of heat and cold presents major challenge. With 3 solar farms you could cut a third or more off the cabling - but not the railway if it is carrying the solar farm. The moving solar farm still needs cabling in addition. The more I think about it the more problems emerge.
1 solar farm locally with enough batteries would be easier (a relative term). A lot easier.
You would need an exceptionally profitable commercial reason - far beyond the need for powering a research base day and night - for a moon circling railroad to make any sense.
  • #35
Yes, but not circling the lunar equator.
Lunar libration of about 10° would require the cable cover 190° longitude of the 80° line of latitude. That defines the optimum (latitude, longitude) of the three solar farms.
They are: A( 80°, -5° ), B( 80°, +5° ), C( 80°, 180° ).
The shortest power line connecting those three farms, all at a latitude of 80°, would be a radial network, having a Y shaped topology, with the long straight stem reaching over the pole, all meeting at a 120° angle close to the two closest farms.
Power at the pole would be convenient since that is where water is expected. The pole also gives maximum radiative cooling to keep electronics cool, and hopefully to keep the over-pole power line superconducting.
  • #36
Al_ said:
Or - of course, if you find a lava tube, that works better.
Shame but I'd guess that lava tubes would be very few and far between. Also, are we sure that they would form in the same way that they form under full gravity. Maybe volcanoes would be higher and that could make the flows very different and the lava could solidify quicker (or slower).
  • #37
sophiecentaur said:
From time to time 'they' suggest projects for supplying Earth with energy from solar satellites. I always see downsides to that. But a similar system of orbiting solar satellites around the Moon could do the same job with some huge advantages; the Lunar Night is long but two or three equatorial satellites could maintain solar power input although probably not in synchronous orbits ( one month period).
The biggest advantage of lunar satellites would be the lack of an atmosphere, so the orbit could be very low. The orbital period could be a few minutes less than 2 hours. In an equatorial orbit, that would give plenty of opportunities to store and dump energy. One hour in the sunlight, one hour in the dark.
  • #38
Only a selected few inclinations in so-called frozen orbits (due to Lunar local mass concentrations) are considered long term stable, namely around inclination 27°, 50°, 76°, and 86°, so a low equatorial Lunar orbit will likely not be stable and require significant station keeping fuel. However, the near polar orbit should be fine in this regards and also have the added benefit of being in full Solar illumination for some days twice a month.
  • #39
Thing is, there's a massive constant supply of solar energy so storage may not actually be necessary. The bigger picture would need to be considered; I can safely say that the population and transport will always be much less than for an Earth situation.
You'd have to compare the cost of storing the energy (and where?- in orbit or on the ground) and just having more satellites to fill in the gaps (re-transmitting to the ground efficiently is also an issue). You'd need materials, however you do it but launching lunar satellites would be easier. Each satellite in a group could target ground stations in turn on the way round.
  • #40
At the same time, it may not actually be necessary to go to the Moon. I am including concepts at this stage, not trying to rule them out. How they might be implemented later, or avoided, is called engineering evaluation.
There is an advantage in reducing the energy storage requirement from two weeks to one hour. For the first satellite, that reduces the energy storage capacity by a factor of 336. It is also more energy efficient, to place one energy cell in lunar orbit, than to decelerate 336 intact cells, to a fixed point on the surface. An energy store and forward satellite could be developed, built, tested, and launched from Earth, well before energy is needed on the lunar surface.
  • #41
I believe batteries could work fine for Lunar bases as they work fine now for arctic bases. Obviously each situation has its own challenges but the article ignores basic strategies such as underground battery storage for thermal insulation and protection.
  • #42
I do think solar and batteries will be the preferred choice for a base if a base gets built, despite needing a lot of them.
Better for Lunar bases than Antarctica where the primary energy source is diesel generators and batteries aren't expected to provide a Winter's worth but used make the electrical systems more efficient.
I think I mentioned this earlier - with high grade insulation and minimal conduction a moon habitat will tend to overheat over time from the energy used within it. Need to be mindful for how the batteries are housed within a habitat complex - where the temperatures are likely to be best - but exceptional reliability that includes very low battery fire risks seems essential.
  • #43
If ever there was a place for stable, consistent nuclear energy the Moon is it.
  • #44
Yet, without our messing with it, it is the Sun that provides that service.
  • #45
A good candidate for large Lunar batteries might be MIT professor Donald Sadoway’s dirt based liquid metal batteries because they could be manufactured on the Moon locally with majority lunar resources.
  • #46
It isn't clear what the energy needs will be. I'm not sure consistently continuous energy will be appropriate for a moon base - although a combination of small nuclear and significant amounts of battery storage could use excess power. There is surely a need for redundancy too - one alone is unlikely to be enough. The modular nature of solar and batteries has redundancy as an innate characteristic.
I remain unconvinced there will ever be more than moon bases for national pride with some science attached and if science based study of the moon is truly the intention remote robotics without astronauts will do it better. I think the optimism for very large bases and expansive moon settlements is mistaken; as thought experiment it can be fun and my participation here is on that basis but I can't take such goals seriously.
Vehicles, drill rigs, excavators probably present a major load intermittent load but solar power directly and accepting a necessity for overnight hibernation could be easier.
Cooling is likely to present problems for nuclear, especially through the Lunar day. If nuclear requires large radiators directed groundwards under shade canopies by day or needs significant amounts of underground piping there is more payload.
Easy to build and convenient with redundancy seems likely to win out over other factors.
"Dirt" in this case seems to be about calcium derived from relatively abundant minerals. Complex mining, refining, manufacturing using Lunar materials ups the on-site requirements enormously rather than reduces them.
  • #47
It reduces the launch mass enormously. The processing might be worked out and automated beforehand. Of course it probably wouldn’t be the first thing they build.
  • #49
I disagree. I think you greatly underestimate the extent advanced manufacturing is dependent on a comprehensively capable wider economy.
Batteries have a variety of materials and components in them of high purity and quality and each draws on yet more equipment, materials, components, expertise. It is like a fractally proliferating complex of interconnected mines, refineries, factories.
Manufacturing of even simple products on Earth is made possible by the ready availability of materials and components, skilled and specialist workers. Factories are built by contractors that can amass the equipment and skilled workforce, access pre-made materials and components and can connect to already available water, power and transport infrastructure.
The notion that we can simply pass all those to some robots in such a distant location with such extreme conditions looks like wishful - magical - thinking to me.
  • #50
All those seas on the Moon, and nobody's suggested pumped hydro?
*runs away*
  • Haha
  • Love
  • #51
  • #52
Sagittarius A-Star said:
NASA’s Apollo missions - from Apollo 12 on - used Plutonium-238 to power the Apollo Lunar Surface Experiments Package (ALSEP), except Apollo 13.
The 4 kg Plutonium of Apollo 13 fall into the pacific ocean on Earth, because the LM was returned to Earth.
Source:
https://www.spacesafetymagazine.com...ion/will-anyone-recover-apollo-13s-plutonium/
Is this scalable? Suitable for a moon base power supply? Enough of them with enough batteries seems possible but other options are possible.
RTG - well, the radioactive decay part - seems best for simple heating uses and the thermoelectric for continuous power supply for low demand applications. With batteries to handle peak demand. Less batteries than for on-site solar.
For electricity production they not very efficient - 20 times more energy as heat than as electricity seems about as good as they get - but that may not be a deciding factor. Heat dissipation - cooling - is essential for them to work and effective use of that waste heat presents some engineering challenges. Is some of that inefficiency a product of use in vacuum, where there is limited or no thermal conduction? I've mentioned heat accumulation within well insulated habitats; the use of heating may be more specific to... hot water, cooking and for lab equipment or recycling systems and not, as it might first seem, for habitat heating during lunar night. It seems to me cooling will present the greater challenges.
The risks of launches going wrong are still quite high. Yes, RTG's can be packaged to resist disintegration and to aid recovery, at a cost of higher payload. I'm not capable of assessing the risks, including the long term effects of being unrecovered and the packaging breaking down but I am inclined towards avoiding launches of such materials where other options exist.
  • #53
I think there may be an application for a Stirling engine or a thermoelectric generator on the Moon. A temperature difference is required. The temperature of the rock 10m down is stable, while the surface gets quite a bit hotter, or colder. There would be two short transition periods each month
  • #55
Nasa plans to have a nuclear reactor on moon.
I have to say this thread seems to have its feet pretty firmly on the ground, discussing what to do with the Moon is far more meaningful than discussing Mars and beyond. We can at least attempt to predict where Engineering will be by the time there's a serious project happening.
  • #56
*runs away*
You jest but since Lunar regolith is fine dust one could effectively use that. Use solar energy to move regolith to a high plateau, of which there are many, during the day and let it move down powering turbines during the Lunar night. Effectively a giant sand filled hourglass.
  • Agree
20K
