Metric for Lambdavacuum EFE - Radial Coordinates
8 replies · 2K views · last reply
redtree
I am having trouble finding the equation for the metric for the Lambdavacuum solution to the EFE in radial coordinates. Any suggestions?
The metric doesn't change with the addition of the Lambda term. So, it's the same as the metric of a 2-sphere. Can you get that?
EDIT: I didn't see you were looking for a vacuum solution. The metric should then be the Minkowski Metric.
The vacuum field solution of empty space with no cosmological constant produces the Minkowski metric:
\begin{equation}
d\vec{s}^2=d\vec{x}^2-dt^2
\end{equation}In radial coordinates, the vacuum field solution around a spherical mass produces the Schwarzschild metric:
\begin{equation}
\begin{split}
d\vec{s}^2&=\left(\frac{1}{1-\frac{\vec{r}_s}{\vec{r}}} \right) d\vec{r}^2 + \vec{r}^2 \left(d\theta^2 + \sin^2\theta d\varphi^2 \right) -\left(1 - \frac{\vec{r}_s}{\vec{r}} \right) dt^2
\end{split}
\end{equation}Which as ##\vec{r}\to \infty## becomes the Minkowski metric, where ##\vec{x}=[\vec{r}, \theta, \varphi]##.I am still not sure how to write metric of the Lambdavacuum solution. What is ##d\vec{s}^2## as a function of ##\Lambda## and ##g_{\mu \nu}##?.
Also look at Carroll's lecture notes from eq. 8.7 onward and you will see the metric and how it relates to Einstein's field equations, including the cosmological constant.
It's the de Sitter metric; see here:
https://en.wikipedia.org/wiki/De_Sitter_space
If by "radial coordinates" you mean coordinates with a radial coordinate ##r## defined the way it is in Schwarzschild coordinates (such that the area of a 2-sphere at radial coordinate ##r## is ##4 \pi r^2##), those are the "static coordinates" described at that link.
That's great. Thanks!
Given:
\begin{equation}
\begin{split}
d\vec{s}^2&=\left(\frac{1}{1-\frac{\vec{r}_s}{\vec{r}}-\frac{\Lambda \vec{r}^2}{3}} \right) d\vec{r}^2 + \vec{r}^2 \left(d\theta^2 + \sin^2\theta d\varphi^2 \right) -\left(1 - \frac{\vec{r}_s}{\vec{r}}-\frac{\Lambda \vec{r}^2}{3} \right) dt^2
\end{split}
\end{equation}
Am I correct in the following, where ##\tilde{\infty}## denotes complex infinity?:
\begin{equation}
\begin{split}
\lim_{\vec{r}\to \infty} d\vec{s}&=\tilde{\infty}
\end{split}
\end{equation}
With a singularity at the transition between real and imaginary values for ##\vec{s}##.
Sure, this is what I quoted for ##m=0## (i.e., ##r_{\text{S}}=0##).
Given:
\begin{equation}
\begin{split}
\end{split}
\end{equation}
Am I right in understanding ##\Lambda## is negative such that ##\frac{\Lambda \vec{r}^2}{3}## is positive?
