A tensor is a multi-linear form, i.e., a function that maps ##n## vectors ##\vec{v}_j##, ##j \in \{1,2,3,\ldots,n \}## to real (I assume a real vector space here as is the case for Minkowski space) numbers, which is linear in each argument, i.e., for any numbers ##\lambda_1## and ##\lambda_2## you have
$$T(\lambda_1 \vec{x}+\lambda_2 \vec{y},\vec{x}_2,\ldots,\vec{x}_n)=\lambda_1 T(\vec{x},\vec{x}_2,\ldots,\vec{x}_n)+\lambda_2 T(\vec{y},\vec{x}_2,\ldots,\vec{x}_n)$$
and analogous rules for all the other arguments. Such a multi-linear form is called a tensor of ##n^{\text{th}}## rank.
In the case of Minkowski space you have a four-dimensional real vector space with a pseudometric, i.e., one has a nondegenerate symmetric bilinear form, i.e., a tensor of second rank. Usually it's written as ##x \cdot y##, where ##x## and ##y## are four-vectors (without an arrow; vectors with an arrow usually means the three spatial components in a given basis). The bilinear form is assumed to be symmetric, i.e., the so defined pseudoscalar product is commutative: ##x \cdot y=y \cdot x##.
Given a basis ##e_{\mu}## you have ##x=x^{\mu} e_{\mu}## and ##y=y^{\mu} e_{\mu}##, where the Einstein summation convention is used, i.e., whenever there is a pair of indices (one subscript one superscript) one has to sum over it. The indices usually run from 0 to 3. Now obviously due to the linear properties oft the pseudometric tensor it is sufficient to know the numbers
$$g_{\mu \nu} = e_{\mu} \cdot e_{\nu}$$
because then you have
$$x \dot y=x^{\mu} e_{\mu} \cdot y^{\nu} e_{\nu}=x^{\mu} y^{\mu} e_{\mu} \cdot e_{\nu}=x^{\mu} y^{\nu} g_{\mu \nu}.$$
The bilinear form is called non-degenerate if the ##4 \times 4##-matrix ##(g_{\mu \nu})## is invertible. There's also a theorem telling that this matrix has always the same number of positive and negative eigenvalues, no matter how you choose the basis. Minkowski space is defined as a space, where the components of the pseudometric form a matrix that has one positive and three negative eigenvector (or the other way around, depending on which sign convention you use; I'm using the socalled "west-coast convention").
Further one can show that there are always pseudoorthonormal bases, i.e., one can choose 4 vectors ##e_{\mu}## such that
$$(g_{\mu \nu}=(\eta_{\mu \nu})=\mathrm{diag}(1,-1,-1,-1).$$
Since ##g_{\mu \nu}## is invertible, it makes sense to define vector components with lower indices by
$$x_{\mu}=g_{\mu \nu} x^{\nu}.$$
Defining ##(g^{\mu \nu})=(g_{\mu \nu})^{-1}##, you get the inverse of this as
$$x^{\mu}=g^{\mu \nu} x_{\nu}.$$
Note that due to the symmetry of the pseudometric the matrices ##(g_{\mu \nu})## and ##g^{\mu \nu}## are symmetric.
Now if you have a trajectory in Minkowski space, a world line, given by a parametrization ##x=x(\lambda)## or for the components with respect to some fixed basis ##x^{\mu} =x^{\mu}(\lambda)##, the derivative ##\mathrm{d}x/\mathrm{d}\lambda=\dot{x}## are tangent vectors along this world line, and you can define the invariant (scalar) quantity
$$\mathrm{d} s^2=\mathrm{d} \lambda^2 \dot{x} \cdot \dot{x}=\mathrm{d} \lambda^2 g_{\mu \nu} \dot{x}^{\mu} \dot{x}^{\nu}.$$
If the world line describes the motion of a massive particle, then its tangent vectors are all time-like, i.e., ##\mathrm{d} s^2>0## at all points of the trajectory, and then it makes sense to define the proper time of the particle by
$$c \tau=\int_{\lambda_0}^{\lambda} \mathrm{d} \lambda ' \sqrt{\dot{x} \cdot \dot{x}}.$$
For a particle at rest in a given pseudoorthonormal coordinate system (Galilean basis), one has ##\vec{x}=\text{const}##, where ##\vec{x}## are the spatial components ##(x^1,x^2,x^3)## with respect to this Galilean basis, you have
$$c \tau=\int_{\lambda_0}^{\lambda} \mathrm{d} \lambda' \dot{x}^0=x^0(\lambda)-x^0(\lambda_0),$$
i.e., up to a conventional factor ##c## (speed of light in vacuum) the proper time of a massive particle is the time measured by a clock comoving with the particle.
