Micromechanics of High Strain Rate Loaded Composite Media
The discussion focuses on the micromechanics of wave propagation in composite materials under high strain rates, emphasizing the influence of fiber orientation, volumetric fraction, and relative moduli on wave characteristics. It suggests starting analysis from a single degree of freedom (SDOF) model and progressing to a multi-degree of freedom (MDOF) model for both unidirectional and woven composites. The conversation notes that composites exhibit higher loss at low frequencies compared to isotropic materials but can behave isotropically at longer wavelengths. For high-frequency signals, the interaction between fabric dimensions and wavelength leads to complex scattering behavior. The speed of sound in the composite is dependent on fiber orientation, and specific details about composition and dimensions are crucial for accurate analysis.
FutureEngineer1720
TL;DR
In Composite materials, How does the wave propagation depends on the physical parameters ( fibre orientation, fibre volumetric fraction, relative fibre modulli etc)?
I would like to know some guidelines regarding this topic. The characteristics of wave propagation depend highly on the orientation of fibre (unidirectional and warp & weft arrangement), fibre volumetric fraction, relative fibre modulli etc. What is the relation of wave propagation and these parameters? I need analysis or At-least a guideline on how to start the analysis? Since I'll be looking things from a micromechanical viewpoint, it will probably be best to start from analysing a unit cell starting from SDOF and then moving to MDOF. Analysis is needed for two cases (1) Unidirectional and (2) woven (with warp and wefts). Any tips or literature on this subject will be highly appreciated.
For low frequency waves a composite will have a slightly higher loss than an isotropic material, but it can be treated as an isotropic material as far as the longest wavelengths are concerned.
For high frequency (ultrasonic) signals, when the dimensions of the fabric start to be similar to the wavelength you will have an array of embeded scatterers with a critical wavelength sensitive behaviour.
If the acoustic impedance of the tensile? and compressive? constituents differ there will be internal reflection and damping of waves.
If the tensile components are not initially under tension there may be a non-linear response to waves resulting in odd harmonic generation, plus even harmonics if slightly bent.
Waves will travel in the faster material with energy being lost into the slower component of the composite material. Expect the speed of sound to be fibre orientation dependent.
You need to be more specific about the composition, dimensions and the wavelength or bandwidth of interest before we can guess what will be most important.
My idea is that I want to use immerse Whitetail Antlers in a fishtank to measure their volumetric displacement (the Boone and Crockett system is the current record measurement standard to place in a juxtaposition with) I would use some sight glass plumbed into the side of the tank to get the change in height so that I can multiply by the tank cross-section. Simple Idea. But... Is there a simple mechanical way to amplify the height in the sight glass to increase measurement precision...
31K
  • · Replies 89 ·
37K
