Midpoint and Trapezoidal Rule (EASY)
  • Thread starter Thread starter medinaj2160
The discussion focuses on the application of the midpoint and trapezoidal rules for numerical integration, specifically using 2, 4, and 8 panels. The results indicate that as the number of panels increases, the midpoint values approach a limit, suggesting the integrand is concave down. The calculation for Simpson's rule using 8 panels yields a value of 2.28954, derived from the formula 2/3(midpoint) + 1/3(trapezoid). The minimum number of function evaluations required for Simpson's rule with 8 panels is 9.
  • Understanding of numerical integration techniques, specifically the trapezoidal rule and midpoint rule.
  • Familiarity with Simpson's rule for approximating integrals.
  • Basic knowledge of function evaluations in numerical methods.
  • Ability to interpret concavity in the context of integrals.
  • Research the derivation and application of Simpson's rule in numerical integration.
  • Learn about the implications of concavity on numerical integration accuracy.
  • Explore the differences between the midpoint and trapezoidal rules in various scenarios.
  • Study the composite trapezoidal rule and its application in more complex integrals.
Students preparing for exams in calculus or numerical methods, educators teaching integration techniques, and professionals applying numerical integration in engineering or data analysis.
medinaj2160
I am solving a sample test for my test on monday, this is the question:
Table(1) have results from applying the midpoint and trapezoidal rule on 2, 4 and 8 panels
npanels...midpoint...trapezoid
2...2.19998820...2.48452890
4...2.26805993...2.33225855
8...2.28422520...2.30015924
1) do these number support the claim that integrand is concave down? Why?
2) Calculate the value of Simpson's rule using 8 panels.
3) what is the minimum number of function evaluations needed to calculate Simpson's rule from scratch on 8 panels?
# 2 is easy: is 2/3(midpoint)+1/3(trappezoid)
Please help me with the other ones.
Thanks
Thanks
Please show us more of your work, per the PF Rules for schoolwork.
there is nothing else to show
Have you actually read the PF rules?
I have, but I don't understand your question. There is nothing else to show, there is no math involve on the other two steps. You or someone that knows what they are doing, should be able to answer question 1 and 3 by looking at the data.
You want more work
2) 2/3(2.28422520)+1/3(2.30015924)=2.28954
Happy?
Thanks, I just need some guidance or someone that can answer this simple question.
You want more work
Happy?
No, sorry. That doesn't help me. Part of the problem is that I don't understand what you are asking. If you could provide more details and background information, that would be a bit help. What is the "trapezoidal rule" that you are referring to? how does it apply to the numbers that you posted?
I'm not trying to be a pain here, but honestly, it would help if you posted a lot more background info, and lead us more into helping us provide hints to what you don't understand.
well, that how the question is written on the sample test.
Trapezoidal rule
From Wikipedia, the free encyclopedia
Jump to: navigation, search
This article is about the quadrature rule for approximating integrals. For the Explicit trapezoidal rule for solving initial value problems, see Heun's method.
The function f(x) (in blue) is approximated by a linear function (in red).
Illustration of the composite trapezoidal rule (with a non-uniform grid)
Illustration of the composite trapezoidal rule (with a uniform grid)
In mathematics, the trapezium rule (also known as the trapezoid rule, or the trapezoidal rule in American English) is an approximate technique for calculating the definite integral
\int_{a}^{b} f(x)\,dx.
The trapezoidal rule works by approximating the region under the graph of the function f(x) as a trapezoid and calculating its area. It follows that
\int_{a}^{b} f(x)\, dx \approx (b-a)\frac{f(a) + f(b)}{2}.
To calculate this integral more accurately, one first splits the interval of integration [a,b] into n smaller subintervals, and then applies the trapezoidal rule on each of them. One obtains the composite trapezoidal rule:
\int_a^b f(x)\,dx \approx \frac{b-a}{n} \left[ {f(a) + f(b) \over 2} + \sum_{k=1}^{n-1} f \left( a+k \frac{b-a}{n} \right) \right].
This can alternatively be written as:
\int_a^b f(x)\,dx \approx \frac{b-a}{2n} \left(f(x_0) + 2f(x_1) + 2f(x_2)+\cdots+2f(x_{n-1}) + f(x_n) \right)
where
x_k=a+k \frac{b-a}{n},\text{ for }k=0, 1, \dots, n
(one can not use a non-uniform grid, as the composite trapezoidal rule assumes equally sized segments).
midpoint
http://www.youtube.com/watch?v=fKtSR0_xf5g"
Your extract from wikipedia is too algebraic for me. If you were to sketch the two cases: (1) concave down and (2) concave up, and draw on each the interpretation of the mid-point and trapezoidal rules, you might then see a way to answering the question.
