MIL-STD-750-3 Transistor Testing
The discussion centers on testing NPN transistors according to MIL-STD-750-3, which primarily provides test methods for PNP transistors. Users can adapt the provided test circuits for NPN transistors by reversing the polarity of the voltage and bias sources, as indicated in the standard. The standard allows for flexibility in circuit configurations, provided that manufacturers demonstrate measurement accuracy. The document is available for free download, facilitating access to the testing guidelines.
  • Understanding of MIL-STD-750-3 testing standards
  • Familiarity with transistor characteristics (Vce, Vbe, hfe)
  • Basic knowledge of circuit design for PNP and NPN transistors
  • Experience with measurement tools like ammeters and voltmeters
  • Review the MIL-STD-750-3 document for detailed test methods
  • Learn about transistor testing configurations for NPN devices
  • Explore best practices for ensuring measurement accuracy in circuit adaptations
  • Investigate common errors in transistor testing and how to avoid them
Electrical engineers, lab technicians, and quality assurance professionals involved in semiconductor testing and compliance with military standards.
MitYeltu
I just want to check my sanity...
I am going to be testing some transistors in a lab very soon per the above mil std. The test methods range from Vce, Vbe, hfe and the breakdown voltages that are listed on the datasheet. The transistor at this point is irrelevant.
Here's what I need to understand. According to the mil std, the circuits are all drawn for PNP trnsistors in one configuration. That's fine. However, I will most,likely be testing NPN transistors. So, if I understand this right, all I need to do is reverse the polarity of the sources and test equipment (ammeter, voltmeter) in order to correctly perform the tests per this std. Is this right?
Is there a different standard for testing NPN transistors? It seems strange that the standard would leave it up to the tester's imagination to come up with the complementary test circuit setups. It's not that hard, but it could be error-prone.
No, there is not a different methods for NPN. That's why I'm asking. I suspect it is merely a matter of reversing things - keep the emitter, collector and base where they are in the circuits, but simply reverse the polarity on the sources. However, as I said, I'm not positive on this and I really don't like burning the UUTs.
I just found out that the standard is available for free download (I'd assumed it was copyrighted and needed to be purchased). Here is one source:
https://snebulos.mit.edu/projects/reference/MIL-STD/MIL-STD-750-3.pdf
And they mention that the PNP circuits are the only ones shown, and others will be used for NPN transistors:
4.2 Test circuits.
The test circuits shown in the test methods of this test method standard are given as examples which may be used for the measurements. They are not necessarily the only test circuits which can be used; however the manufacturer shall demonstrate to the Government that other test circuits which they may desire to use will give results within the desired accuracy of measurement. Circuits are shown for PNP transistors in one circuit configuration only. They may readily be adapted for NPN devices and for other circuit configurations.
And in the Notes for Figure 3011-1, they do say to reverse the sources for NPN transistors:
NOTES:
1. A PNP device is shown. For NPN types, reverse the polarities of the voltage and bias sources and zener diode
I think in general reversing the polarity of the sources should work for most testing of PNP/NPN transistors, but if you have a question about a particular circuit that you want to verify, go ahead and post the two versions here in this thread so we can double-check them. :smile:
  • · Replies 75 ·
9K
