Vanadium 50 said:
Your problem is that you have a very low power transmitter right next to a high powered star.
I would have preferred the option of giving your reply an "informational" well as a "like" at the same time, I went with the like because to me that also confers informational. It would be very difficult to find a site more informational than PF.
Although I'm not familiar with the technical aspects you mention with the RTG or the power limitations of the transmission, it does make perfect sense when considered from my limited understanding. I see that signal to noise would be better phrased as noise to signal, you raise a very valid point.
I'm assuming, from my understanding of Starshot and discussions here on PF, in particular,
https://www.physicsforums.com/threads/beam-powered-propulsion-keeping-the-beam-focused.896207/ that both the propulsion as well as the communication channel transceiver would best be located in orbit or relayed from GSO, particularly if an optical link verses some other form of energy were used (I'll bet on optical). As to the power supply, I'm imagining that powerbeaming will be a strong contender. I recently posted something on that in the SS & launch info or traveling to Mars thread but here's an example link,
https://nps.edu/web/eag/emerging-game-changing-technology-power-beaming
I see that the early power estimations by Starshot called for a 100 GW phased array system, not sure yet if that's been revised but whatever power source is utilized, that should keep the engineers sharpening their pencils for some time.
I'd like to see
@kolleamm post back with any thoughts or questions. I believe the Di- part of Dialogue is what makes a forum most beneficial for everyone.
Thanks, Scott
