Minimal polynomial of a vector under matrix powers
7 replies · 2K views · last reply
Artusartos
Let [itex]A \in M_n(F)[/itex] and [itex]v \in F^n[/itex]. Let k be the smallest positive integer such that [itex]v, Av, A^2v, ..., A^kv[/itex] are linearly dependent.
a) Show that we can find [itex]a_0, ... , a_{k-1} \in F[/itex] wiht
[itex]a_0v + a_1Av + ... + a_{k-1}A^{k-1}v + A^kv = 0[/itex]
(note that the coefficient of A^kv is 1). Write
f(x) = x^k + a_{k-1}x^{k-1} + ... + a_0.
Note that f(A)(v)=0.
b) Show that f is a monic polynomial of lowest degree with f(A)(v)=0.
I tried to answer these questions, but I'm not sure if my answers are correct...can anybody please check them for me?
a) Since k be the smallest positive integer such that [itex]v, Av, A^2v, ..., A^kv[/itex] are linearly dependent, we know that [itex]v, Av, A^2v, ..., A^{k-1}v[/itex] is linearly independent. So, for [itex]v, Av, A^2v, ..., A^kv[/itex], we know that for any linear combination of these elements, there exists a coefficient that is nonzero (when the whole equation is zero)...In other words:
[itex]b_0v + b_1Av + ... + b_{k-1}A^{k-1}v + b_kA^kv = 0[/itex] for b_0, ... , b_k not all zero.
Now if we divide the whole equation by b_k, we get
[itex]\frac{b_0}{b_k} v + \frac{b_1}{b_k} Av + ... + \frac{b_{k-1}}{b_k} A^{k-1}v + A^kv = 0[/itex].
If we denote [itex]\frac{b_m}{b_k}[/itex] by [itex]a_m[/itex] (where m is between zero and k), we get...
Now to show that f(A)(v)=0 ...
[itex]f(A)(v) = (A^k + a_{k-1}A^{k-1} + ... + a_0v)(v) = a_0v + a_1Av + ... + a_{k-1}A^{k-1}v + A^kv = 0[/itex]
b) [itex]f(A) = f(A)(v) = (A^k + a_{k-1}A^{k-1} + ... + a_0v)(v) = a_0v + a_1Av + ... + a_{k-1}A^{k-1}v + A^kv = 0[/itex]
Can anybody check if I'm right? I'm also not sure if I understood the questions correctly?
For part (a), you should explain why you know that [itex]b_k[/itex] is nonzero, so you can divide by it.
For part (b), you have shown that f(A)(v) = 0. Obviously f is monic. Why is it a lowest degree polynomial with f(A)(v) = 0, i.e. why can't this be true for a lower degree polynomial?
For part a), [itex]b_k[/itex] is nonzero, because [itex]v, Av, ... , A^kv[/itex] is linearly dependent...so when the equation is zero, not all of the coefficients are zero...
For part b), this cannot be true for a polynomial of a lower degree, because [itex]v, Av, ... ,A^kv[/itex] is the smallest k such that [itex]v, Av, ... ,A^kv[/itex] is linearly dependent. So if we had [itex]v, Av, ... ,A^{k-1}v[/itex], then the basis would b independent, so all the coefficients would need to equal zero when f(A)(v) = 0. So the function wouldn't be monic anymore.
Do you think my answers are correct?
They're not all zero, but some of them could be. How do you know that [itex]b_k[/itex] in particular is not zero?
Yes, correct.
jbunniii said:
They're not all zero, but some of them could be. How do you know that [itex]b_k[/itex] in particular is not zero?Yes, correct.
Because I know that the rest is the linearly independent basis. The extra one is [itex]b_kvA^k[/itex]
Thanks a lot.
I also have two other questions, if you don't mind...
1) Let [itex]V=Span(v, Av, A^2v, ... , A^{k-1}v )[/itex]. Show that V is the smallest A-invariant subspace containing v. We denote this fact by writing
V=F[x]v
This corresponds to the F[x]-module structure on [itex]F^n[/itex] induced by multiplication by A.
2) Show that [itex]v, Av, A^2v, ... , A^{k-1}v[/itex] is a basis, B, for V.
My answers:
1) We know that V is T-invariant because,
[itex]T_A(v) = Av = vx_1 + Avx_2 + ... + A^{k-1}x_k \in V[/itex]
since [itex]Av = vx_1 + Avx_2 + ... + A^{k-1}x_k[/itex] is a linear combination of the span of V.
We know that it is the smallest one, because if [itex]V = Span (v, Av, ... ,A^{k-2}v)[/itex], for example, then not all of [itex]A^wv[/itex] (w in F) would be a linear combination of [itex](v, Av, ... , A^{k-2}v)[/itex] (we also know that [itex](v, Av, ... , A^{k-2}v)[/itex] is a non-square matrix, so it cannot be a basis), since we know from the first question that I asked that [itex](v, Av, ... , A^{k-1}v)[/itex] is a basis for F.
2) Since [itex]V=Span(v, Av, A^2v, ... , A^{k-1}v )[/itex], we know that [itex][v|Av|...|A^{k-1}v][/itex] has a pivot position in every row. We also know that it is a square matrix, from the very first question that I asked...so it must also have a pivot position in every column. Thus, it is one-to-one and onto...and must be a basis for V.
Thanks in advance
Artusartos said:
Thanks a lot.
V=F[x]v
Does [itex]k[/itex] still have the same meaning as in the first problem? i.e. it's the smallest power such that [itex]v,Av,A^2v,\ldots,A^{k-1}v,A^{k}v[/itex] are linearly dependent? I will assume so, because the statement isn't necessarily true for an arbitrary [itex]k[/itex].
My answers:
This doesn't seem quite right. An arbitrary element of [itex]V[/itex] can be written as follows:
[tex]v = vx_1 + Avx_2 + \ldots + A^{k-1}vx_k[/tex]
Therefore
[tex]Av = Avx_1 + A^2vx_2 + \ldots + A^{k-1}vx_{k-1} + A^{k}vx_k[/tex]
Now you have to use the fact that [itex]A^{k}v[/itex] is a linear combination of [itex]v,Av,A^2v,\ldots,A^{k-1}v[/itex].
OK, that's one particular subspace with lower dimension than [itex]V[/itex]. But you need to prove that NO subspace with lower dimension than [itex]V[/itex] can be an [itex]A[/itex]-invariant subspace containing [itex]v[/itex]. Hint: to do this, you need to show that any such subspace must contain all of the vectors [itex]v, Av, ... ,A^{k-1}v[/itex].
I don't think you need to talk about rows and columns here. A basis is a linearly independent set of vectors which spans the space. Well, by definition, [itex]v, Av, A^2v, ... , A^{k-1}v[/itex] spans [itex]V[/itex], so all you need is that this is a linearly independent set. But that's also given, isn't it?
Yes it does have the same meaning.
Therefore
So, can I answer it like this:
From the very first question that I asked, we know that the equation [itex]a_0v + a_1Av + ... + a_{k-1}A^{k-1}v + A^kv = 0[/itex] is true. So
[itex]A^kv = -a_0v - a_1Av - ... - a_{k-1}A^{k-1}v[/itex]
So if we let [itex]y_m = -a_m[/itex] for m = 0, 1, ... , k-1,
[itex]A^kv = y_0v + y_1Av + ... + y_{k-1}A^{k-1}v[/itex]
From here, we can see that any [itex]A^kv[/itex] can be written as a linear combination of [itex]v, Av, ..., A^{k-1}v[/itex]. Since V is spanned by these elements, then [itex]A^kv[/itex] is alo in V. So V is A-invariant.
So if we look at this equation again:
[itex]A^kv = y_0v + y_1Av + ... + y_{k-1}A^{k-1}v[/itex], we will see that [itex]A^kv[/itex] can be written as the linear combination of [itex]v, Av, ... , A^{k-1}[/itex]. Since [itex]v, Av, ... ,A^{k-1}[/itex] is linearly independent, we know that we cannot write [itex]A^kv[/itex] as a linear combination of these elements if we take any of them away. So, V must be the smallest.
Yes it is given.
