Minimal Surface between two different coaxial circules
  • Context: Graduate
  • Thread starter Thread starter RafaelPetros
    Coaxial Surface
The discussion revolves around finding the minimal surface of revolution between two coaxial circular rings of different diameters. Participants explore numerical solutions and theoretical implications related to the geometry of minimal surfaces.
  • Exploratory, Technical explanation, Debate/contested
  • One participant seeks a solution for the minimal surface of revolution between two coaxial rings of different diameters, noting difficulties in finding existing solutions online.
  • Another participant suggests that the solution depends on the spacing between the rings, proposing that a hyperbolic cosine curve may apply when the rings are close, while a different configuration may occur when they are further apart.
  • A participant questions the source of the previous claim about the spacing and surface energy, prompting a response that the information was derived from personal experience rather than literature.
  • There is a challenge regarding whether a closed form solution exists for circles of different diameters, with a reference to known solutions for equal circles.
Participants express differing views on the existence and nature of solutions for minimal surfaces between coaxial rings of different diameters, indicating that the discussion remains unresolved with multiple competing perspectives.
Participants reference specific mathematical systems and concepts, but the discussion lacks detailed definitions and clarity on assumptions regarding the configurations of the rings.
RafaelPetros
Dear All,
I am trying do find the minimal surface of revolution between two coaxial circular rings of DIFFERENT diameter.
I could not find it solved in the net. So I tried to solve numerically system (13-14) Minimal Surface of Revolution -- from Wolfram MathWorld
to determine "a" and "b" for given coordinates did not work I got complex solutions...
If anyone knows where I can find the solution of this problem or if anyone can give more info on this will be grate.
Thanks.
It depends upon the spacing between the rings. If they are close enough, the solution is a hyperbolic cosine curve (IIRC), but if they get further apart, this solution involves too much surface energy and the solution degenerates to a film covering each circle and a line connecting them.
Thanks for reply. Could you pleas tell me were did you red this?
I did not read this. I worked the problem years ago.
Then what is this function of distance between two coaxial rings of different diameters?
I forget, and I do not need to know at the present time. If I did, I would work it out. I suggest the same to you.
Are you sure that you obtained closed form solution for circles which have different diameter?
Solution for the case when circles are equal is well known and also it is in the link which is in my post.
Yes.
  • · Replies 35 ·
9K
