Minimize the following using K-Map and implement using universal gates
  • Thread starter momentum
    Universal
4 replies · 2K views · last reply
momentum
Problem:
minimize the following using K-Map and implement using universal gates
f=sum of m( 2,3,6,7,8,10,11,13,14)My Solution
Here is my solution
https://prnt.sc/jdyk0k
However, my solution is not matching with book solution
Book solution
https://prnt.sc/jdyj4n
Handwritten 4-variable Karnaugh map with CD columns 00, 01, 11, 10 and AB rows 00, 01, 11, 10, with 1s grouped in circled loops, above the expression f = BC + CD' + A'C + ABD' + A'B'CD' underlined in red.
I'm confused. which solution is correct?
  • Handwritten 4-variable Karnaugh map with CD columns 00, 01, 11, 10 and AB rows 00, 01, 11, 10, with 1s grouped in circled loops, above the expression f = BC + CD' + A'C + ABD' + A'B'CD' underlined in red.
The book solution is correct. You do not appear to be mapping the minterms to the K-map cells properly. If you could explain how you are mapping the minterm "3", for example, additional help could be provided.
Ok.. understood.
I did the correction. Now I have 2 solutions to this problem.
Solution # 1
Handwritten 4-variable Karnaugh map with rows AB and columns CD, cells numbered 0 to 15, several 1s circled in groups, and the sum-of-products result Y = A'C + CD' + AB'C + AB'D' + ABC'D written below.
And
Solution # 2
Handwritten 4-variable Karnaugh map with rows AB and columns CD, with 1s circled and boxed in red, and below it the sum-of-products expression Y = A'C' + CD' + (partly obscured) B'C' + AB'D' + ABC'D.
But Book has given only Solution # 2 . Did they missed Solution # 1 ?
Do you think Solution # 1 is invalid ? Or Book just missed to print solution#1
Please correct me If I can write Solution # 1 as a possible solution to this problem. I'm stuck at this point.
  • Photobucket notice on a grey background showing a speedometer-style gauge at 100% labelled 3rd Party Hosting Usage, with the text: IS THIS YOUR PHOTO? PLEASE UPGRADE YOUR PHOTOBUCKET ACCOUNT TO ENABLE 3RD PARTY HOSTING.
  • Photobucket notice on a dark grey background with a speedometer-style gauge reading 100% labelled 3rd Party Hosting Usage, advising users to upgrade their account to enable 3rd party hosting.
  • Handwritten 4-variable Karnaugh map with rows AB and columns CD, cells numbered 0 to 15, several 1s circled in groups, and the sum-of-products result Y = A'C + CD' + AB'C + AB'D' + ABC'D written below.
  • Handwritten 4-variable Karnaugh map with rows AB and columns CD, with 1s circled and boxed in red, and below it the sum-of-products expression Y = A'C' + CD' + (partly obscured) B'C' + AB'D' + ABC'D.
Solution 1 is valid, but solution 2 is more simplified. When doing K-map grouping, if any group can be extended, extend it.
