Minimum distance from a repulsive central force
4 replies · 2K views · last reply
gcfve
A particle of mass m moves under action of a repulsive central force Fr=Cr-3 with constant C greater than 0. At a very large distance from the centre of the force, the partcle has kinetic energy K and its impact parameter is b. Use conservation of energy and angular momentum to show that the closest m comes to the centre of force is rmin=[tex]\sqrt{b^2+ C/2K}[/tex]
L=mbv0
E=[tex]\frac{1}{2}[/tex]mvr2+L2/2mr2+V(r)
So far, I said that since the object is far away its total energy is K
I think V(r) = -3C/r2, but I'm not sure.
And at rmin, E==[tex]\frac{1}{2}[/tex]mvrmin2+(mbv)2/2mr2-3C/rmin2
I don't know what to do next.
PHY2333...Assignment is due tomorrow... Still can't get this either. Where do you get -3C/r^2 for V(r)? Would it not be -0.5C/r^2?
Take Force integrate from rmin to b, as when r is infinity, it will approximately equal to be, because it is essentially uneffected by the force anyway. this integration will give you the answer. I know its not using angular momentum, but I don't care at this point.
