Minimum kinetic energy of an Alpha particle confined to a nucleus
The minimum kinetic energy of an alpha particle confined to a nucleus is calculated to be approximately 0.052 MeV using the formula h²/2ma². The calculation involves constants such as Planck's constant (h = 1.05 x 10^-34 J·s) and the mass of the alpha particle (m = 6.64 x 10^-27 kg) with a confinement radius (a = 10^-14 m). The typical energy of the alpha particle is around 5 MeV, leading to a minimum kinetic energy estimate of 4.948 MeV when accounting for uncertainty. The discussion also highlights the importance of the energy-time uncertainty principle in these calculations.
  • Understanding of quantum mechanics principles
  • Familiarity with the uncertainty principle
  • Knowledge of basic nuclear physics
  • Proficiency in using physical constants and units
  • Study the energy-time uncertainty principle in detail
  • Learn about the implications of confinement in quantum mechanics
  • Explore calculations involving kinetic energy in nuclear physics
  • Investigate the role of Planck's constant in quantum calculations
Students and educators in physics, particularly those focusing on quantum mechanics and nuclear physics, as well as researchers interested in the behavior of particles at the atomic level.
Brianrofl
http://puu.sh/bz0km/092f2d8781.png
h^2/2ma^2
I've found the uncertainty of the kinetic energy through many means, and I'm confident that it's .052MeV.
The easiest method that gave me this answer was:
using http://puu.sh/bz0Fm/f45f952a89.png
((1.05*10^-34)^2 / 2(6.64*10^-27)(10^-14)^2 ) / 1.6*10^-19 = .052MeV
So I know that the kinetic energy has an uncertainty of .052MeV and that its typical energy is 5MeV, so wouldn't the answer just be 5MeV - .052MeV = 4.948MeV?
In this type of question, the uncertainty in momentum is generally taken to be an estimate of the minimum momentum itself. Thus, the KE of .052 MeV would represent an estimate of the minimum KE of the alpha particle inside the nucleus. Did you try using .052 MeV as the answer?
You also have to be careful in that different people will use somewhat different expressions for the right side of the uncertainty principle: h, h-bar, h-bar/2, etc.
Wow, when I first put in my answer I put in .51 instead of .519, so it got marked as wrong :( I was right the whole time.
There is this problem, though -- http://puu.sh/bz4AT/4545a75828.png
I can't even find anything like it in my textbook, any tips just to get me started on it?
Thanks.
Is that meant to be 0.0519 MeV?
Thanks.
Are you familiar with the energy-time uncertainty principle? See http://pdg.web.cern.ch/pdg/cpep/unc_vir.html
Yeah
Ok, yeah I've used that equation before and I got the correct answer, thanks!
  • · Replies 24 ·
  • · Replies 17 ·
15K
