Minimum-maximum problem with graph plotting
  • Thread starter Thread starter Karol
    Graph Plotting
4 replies · 2K views · last reply
Karol
The first derivative of the area ##~\displaystyle A(a)=a\sqrt{r^2-\frac{a^2}{4}}## is positive everywhere
When f'(x)>0 → the function rises
$$A'=a\frac{1}{2}\left( r^2-\frac{a^2}{4} \right)^{-1/2}\cdot\left( \frac{1}{4} \right)2a+\sqrt{r^2-\frac{a^2}{4}}$$
$$A'=...=\frac{2r^2-a^2}{\sqrt{4r^2-a^2}}>0$$
I found A'=0 at ##~\displaystyle a=\frac{2}{\sqrt{5}}r##
No: ##A^{\prime} \neq 0## at ##a = r \; 2 /\sqrt{5},## as you can see from your own expression for ##A^{\prime}##.
Anyway, for a rectangle of base ##a## we need ##a < 2r##, so having a maximum of ##A(a)## at ##a > r## is perfectly OK.
$$\frac{2r^2-a^2}{\sqrt{4r^2-a^2}}=0\rightarrow a=\sqrt{2}r$$
But still A'>0 for 0<a<2r
It should be negative for a>√2⋅r
It IS negative for ##a > r \sqrt{2}##.
If you don't believe it, try plotting ##A(a)## for ##r = 1## and ##0 < a < 2##.
