Minimum or Maximum value of a multivariate function
The discussion revolves around finding the minimum or maximum value of a multivariate function composed of several independent quadratic functions, subject to a constraint on their sum. The original poster describes a scenario with multiple variables, each represented by a quadratic function, and a constraint that the sum of these variables equals a specified value.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of Lagrange multipliers to incorporate the constraint into the optimization problem. There are questions about how to handle the ranges for each variable while applying this method.
Some participants have provided guidance on using Lagrange multipliers and suggested exploring interior point methods to manage the constraints. The original poster acknowledges this input and seeks further clarification on handling variable ranges.
The original poster mentions specific ranges for each variable, indicating that these constraints must be considered alongside the equality constraint. There is an ongoing exploration of how to effectively incorporate these limits into their approach.
jkim8512
Not a hw
First thank you for taking your time to take a look at this simple question. And sorry for the informal math language and equations, I hope you guys can understand it.
So, depending on the case, I have 2 or 8 simple quadratic functions f(a), f(b), f(c),… f(z).
Each a,b,c,…,z have a different range for f(a),f(b), f(c), .. ,f(z). These functions are all independent to each other, they are just simple quadratic functions.
These functions adds up to get one value f(T).
The constraint is that the sum of a,b,c,…,z should be a given value N.
And what I want is the Minimum or maximum value of f(T)So, If I right it down in some simple math, it looks like this.
f(T) = f(a) + f(b) + f(c) + f(d)+….+f(z)
constraint: N = a+b+c+d+….+z
goal: Find minimum or maximum value of f(T) when N is given.
where,
f(a) = simple quadratic function such as 3a^2+ 4a+ 5, range: a_start < a < a_end
f(b) = simple quadratic function such as 3b^2+ 4b+ 5, range: b_start < b < b_end
f(c) = simple quadratic function such as 3c^2+ 4c+ 5, , range: c_start < c < c_end
………… same up to f(z)
I googled some stuff and found I could probably use “Max/min for functions of multi variables” things like that.
The main problem I can’t figure out is how to deal with the constraints I need to have regarding N=a+b+c,..+z
Thanks again!
Your notation is pretty bad, it would be a lot clearer if your wrote ##f(x_1,...,x_n) = f_1(x_1)+...+f_n(x_n)##.
The thing you need to use to incorporate the constraint is lagrange multipliers.
https://en.m.wikipedia.org/wiki/Lagrange_multiplier
Basically the idea is that gradient of the function you are minimizing has to be parallel to the gradient of the constraint.
Thank you so much. It seems like the right thing to look at.
You can have a look at the LaTeX Guide link in the lower left of the Edit window to see how to best post math equations online... :smile:
First thank you all for the kind reply.
I took a look into Lagrange multipliers. It seems like what I need to use.
However I still have one question. I am not sure about how to limit the range for x1,x2, x3, … ,xN
I want to find
Max/min of: f(x1,x2,…,xn) = f1(x1) + f2(x2) +... +fn(xn)
Constraint: x1+x2 +...+xn =N
X1 range: x1_start < x1 <x1_end
X2 range: x2_start < x1 <x2_end
X3 range: xn_start < xn <xn_end
I googled how to use the contraint by using the Lagrange multipliers. And I think i can do it.
But, I still don’t know what to do with the ranges for x1, x2, ... ,xn. Can you guys give me any hint for it or tell me what i have to look into?
Thanks!
Have a wonderful weekend!
You are trying to extremize <br /> f(x_1, \dots, x_n) = \sum_{i=1}^n f_i(x_i) subject to x_1 + \dots + x_n = N and m_i \leq x_i \leq M_i for i = 1, \dots, n. The equality constraint can be enforced by using a lagrange multiplier and extremizing instead the function <br /> F(x_1, \dots, x_n, \lambda) = f(x_1, \dots, x_n) + \lambda\left(\sum_{i=1}^N x_i - N\right). It looks like an Interior point method might work to maximize F, since that will also enforce contraints of the form c_{2i-1}(x_1, \dots, x_n,\lambda) = x_i - m_i \geq 0 and c_{2i}(x_1, \dots, x_n, \lambda) = M_i - x_i \geq 0, ensuring that the extrema are in the acceptable range of x_i.
