Minimum string tension needed to move the block
The discussion revolves around a physics problem involving a steel block on a table, where participants explore the minimum string tension required to initiate movement, the effects of static and kinetic friction, and the subsequent speed of the block after moving a certain distance. The subject area includes concepts of friction, Newton's laws, and kinematics.
  • Mixed
  • Participants discuss the calculation of minimum tension needed to overcome static friction and the subsequent calculations for acceleration and speed when the block is in motion. There are questions about the net force and the application of kinetic friction once the block starts moving.
There is ongoing exploration of the calculations related to net force and acceleration, with some participants providing hints and guidance on using kinematic equations. Multiple interpretations of the problem are being discussed, particularly regarding the transition from static to kinetic friction.
Participants are working under the constraints of homework guidelines, which may limit the information they can use or the methods they can apply. There is also a focus on ensuring calculations are accurate and consistent with the principles of physics.
alexas
A 1.50 kg steel block is at rest on a steel table. A horizontal string pulls on the block. The coefficient of static friction of dry steel on steel is Uk=.800, the coefficient of kinetic friction of dry steel on steel is Uk=.600, and the coefficient of kinetic friction of lubricated steel on steel is UkLUBE=.050
What is the minimum string tension needed to move the block?
If the string tension is 19.0 N, what is the block's speed after moving 1.30 m?
If the string tension is 19.0 N and the table is coated with oil, what is the block's speed after moving 1.30 m?
F = (Uk)mg
F = (.8)(1.5)(9.8) = 11.76
F = 11.8
Since we know we need at least 11.8 to get it to move, we have an additional 7.2N
So i figured...
F = ma
7.2 N = (1.5kg)a
a = (7.2)/(1.5)
a = 4.8 m/(s^2)
Anyways, I am a little confused on what to do after i have the acceleration.
I figure i could approach this the same was as the second question but i would basically just need to recompute the minimal tension required to move it.
Your first answer on the minimum force necessary to move the block is correct, but the other answers are incorrect, because the block is moving. The net force is not 7.2N. Once you get the acceleration, you can get the speed after 1.3 m by using the kinematic equations, but it is easier to use the Work-Energy theorem, if you are familiar with it.
How would icorrectly calculate the net force since its not 7.2N? Or what should I calculate first? I need the acceleration right?
Any more hints?
I don't get why the net force isn't 7.2N if i add the right pushing forcing that's 19N and the left pushing for that's 11.8N (19N - 11.8N = 7.2N ?)
Now, basically the kinetic friction coefficient can be used to account friction only when the block starts moving. The moment the block starts to move, the static friction reduces to kinetic friction and the opposition to the applied force gets reduced so that the body can accelerate. Keeping this point in mind, you can calculate the block's speed with the help of kinematic equations.
So instead could i assume with 19N being applied the total net force after traveling 1.3m would be:
F = (.6)(1.5)(9.8) = 8.82N
19N - 8.82N = 10.18N
10.18 N is the total net force?
Taking this netforce
A = -(Uk)(g) = -(.6)(9.8) = 5.88
X1 = -(V^2)/2(-5.88)
Since we know X1
1.3 = [-(V^2)]/[2(-5.88)]
negatives will end up canceling out...
1.3 = [(V^2)]/[2(5.88)]
simply multiplication...
1.3 = [(V^2)]/[11.76]
more multiplication...
15.288 = (V^2)
Square root of 15.288
3.90 m/s I know the answer is wrong but that's what I've come up with right now...
What I meant was, you've applied the minimum force to move the block. Let that be the same. instead for the static friction coefficient, now the block's movement would be resisted only by kinetic friction. Evaluate the same equations using the kinetic friction coefficient. Find out the net acceleration and use kinematic relations.
Isn't that what i did?
Well, that is the idea. See if your calculations are right.
Everything seems to check out mathematically. Am i using the wrong equation anywhere?
Yes, that is correct.
What was that step for?
Net force = Mass X Acceleration.
Find out acceleration and solve the rest.
Alright so if that's the case...
Acceleration would equal 3.92 (m/(s^2) correct?
No, what is the mass of the block? 1.5 Kg.
What is the net force? 10.18 N.
Calculate acceleration!
I used 5.18N as the netforce for my calculations earlier, now that i used 10.18N as my netforce my acceleration should be correct since it is: 6.78 m/(s^2) ?
Tell me if you've got it right. I may be wrong, you know.. :rolleyes:
Yes, go on. Solve the rest and tell me if you get it right.
Got it!
I used:
Vf = final velocity, which we are trying to find
Vi = initial velocity, which is 0?
a = 6.67m/s
X = 1.3m
(vf^2) = Vi + 2aX
Anyways after a bit of math the final velocity it reaches when it is at 1.3m is: 4.16 m/s
Which by the way is correct. However, i was supposed to give the answer as 4.20 instead (something about sig figs) but anyways, i got that part. I'm going to do the next part, but that should be easy to do now *i hope*.
And for the second part basically following the same methods from before, the correct answer is: 5.16
Ok. Great. You get the ideas right, then everything is okay. You should understand why the kinetic coefficient is used immediately after the block moves. Problems do vary. You may not be able to apply the same thing to each problem.
That is what frustrates me the most. haha
It always seems fairly simple once you know all the steps to a problem.
  • · Replies 18 ·
