Minimum variance unbiased estimator
  • Thread starter Thread starter dvvv
    Minimum Variance
8 replies · 3K views
dvvv
Let [itex]\bar{X}[/itex]1 and [itex]\bar{X}[/itex]2 be the means of two independent samples of sizes n and 2n from an infinite population that has mean μ and variance σ^2 > 0. For what value of w is w[itex]\bar{X}[/itex]1 + (1 - w)[itex]\bar{X}[/itex]2 the minimum variance unbiased estimator of μ?
(a) 0
(b) 1/3
(c) 1/2
(d) 2/3
(e) 1
If θ~ is unbiased for θ and
Var(θ~)= 1/E[(d loge f (x)/dθ)^2] = 1/E[(dl(θ)/dθ)^2]
then θ~ is a minimum variance unbiased estimator of θ.
E[w[itex]\bar{X}[/itex]1 + (1 - w)[itex]\bar{X}[/itex]2] = wμ + (1-w)μ = μ
So it's an unbiased estimator of μ.
I tried calculated the variance but I guess it's wrong.
Var[w[itex]\bar{X}[/itex]1 + [itex]\bar{X}[/itex]2 - w[itex]\bar{X}[/itex]2] = w^2.σ^2/n + σ^2/n + w^2.σ^2/n = σ^2/n(2w^2 +1)
I think I have to use the formula above but I don't know how.
Thanks.
(a) 0
(b) 1/3
(c) 1/2
(d) 2/3
(e) 1
Thanks.
Note: use brackets, since otherwise your expressions are ambiguous. Better yet, use LaTeX, as you did in the first part of your post.
Your variance formula is incorrect. Since [itex]\bar{X}_1[/itex] and [itex]\bar{X}_2[/itex] are independent we have
[tex]\text{Var}(a \bar{X}_1 + b \bar{X}_2) = a^2 \text{Var}(\bar{X}_1) + b^2 \text{Var}(\bar{X}_2)[/tex]
for any constants [itex]a, \: b.[/itex] Use [itex]a = w[/itex] and [itex]b = 1-w.[/itex]
I don't know why you wanted to write (1-w)X as X - wX and then apply the variance formula, but you did it incorrectly. Using V(.) for the variance of a random varable, we have (using the fact that X and X are dependent): [tex]V(X - wX) = 1^2 V(X) + w^2 V(X) - 2 \cdot 1\cdot w\: \text{Cov}(X,X),[/tex] and, of course, [itex]\text{Cov}(X,X) = V(X).[/itex]
RGV
I don't know why I did that either.
So is it right to say:
[tex]\text{Var}( \bar{X}_1) = \text{Var}(\bar{X}_2) = σ^2/n[/tex] ?
How do I work out what w is?
In terms of sigma, what would be the variance of a sample mean of size 10 (that is, n=10)? What about for a sample of size 20? Now go back and read (carefully) the original question. Do you honestly still need me to answer?
RGV
RGV
I guess it would be (σ^2)/10 and (σ^2)/20, so it's (σ^2)/n and (σ^2)/2n for [itex]\bar{X}_1[/itex] and [itex]\bar{X}_2[/itex], respectively.
I subbed that into
and subbed in a and b, and I got
[tex](σ^2(w^2+1))/2n[/tex]
I still don't know how to get w, sorry...
I subbed that into
No wonder: you have made a serious algebraic blunder, so you end up with the wrong expression.
RGV
dvvv said:
Tried again and got:
[tex]((3 w^2 - 2 w + 1) σ^2)/(2 n)[/tex]
which is correct according to wolfram alpha http://www.wolframalpha.com/input/?i=w^2(σ^2/n)+(1-w)^2(σ^2/2n)
What now?
You should not need a powerful tool to do such simple, high-school algebra, but since you have already done it, OK. The question asked you to find the value of w that minimizes the variance. So, that is what you need to do. At this point I am signing off this thread.
RGV
I just used it to confirm I was right. Thanks for your help.
