Minkowski normal v. Euclidean normal
The discussion revolves around the differences between the concept of a normal vector in Minkowski spacetime and in Euclidean space. Participants explore theoretical aspects, geometric interpretations, and implications of these differences in the context of physics and geometry.
  • Some participants clarify that "normal" is being used as a synonym for "orthogonal" in the context of the discussion.
  • One participant notes that in Minkowski space, certain non-zero vectors can be orthogonal to themselves, raising questions about the conditions under which this occurs.
  • Another participant describes the geometric interpretation of normals in both Minkowski and Euclidean spaces, suggesting that the tangent line to a Minkowski-circle is perpendicular to the radius, similar to Euclidean circles.
  • A participant explains that when a timelike vector is orthogonal to a spacelike vector, it relates to an observer's perception of simultaneity, indicating a connection between the observer's time axis and spatial axes.
  • One participant suggests that the dimensionality of Minkowski spacetime introduces complexities that affect the degrees of freedom for normals compared to Euclidean space.
  • References to external resources, such as diagrams and definitions, are provided to support various viewpoints and clarify concepts.
Participants express differing interpretations and understandings of the concept of normals in both spaces, indicating that multiple competing views remain without a consensus on the topic.
Some discussions involve assumptions about the dimensionality of the spaces and the nature of the vectors involved, which may not be fully resolved within the thread.
flyinjoe
What is the difference between the normal in Minkowski spacetime and the normal in Euclidean space?
Yes, sorry, I am sort of using normal as a synonym for orthogonal. Essentially, how would vector that is normal to a surface in Minkowski spacetime differ from a vector normal to the same surface embedded in Euclidean space?
I was thinking it had something to do with the magnitude function in the determination of the normal vector being different in each space (i.e., the denominator of the equation for a normal vector).
I'm sorry if this isn't making much sense.
In a typical 1+1-dimensional spacetime diagram, a line through the origin with slope v is "orthogonal" (with respect to the Minkowski metric) to a line with slope 1/v. In particular, the x' axis in the image below is orthogonal to the t' axis.
In other words, as you tilt a line through the origin, the line through the origin that's orthogonal to it is tilted by the same amount as in the Euclidean case, but in the opposite direction.
In Minkowski space, some non-zero vectors are orthogonal to themselves, i.e., the hypersurface normal to a vector can include the vector!
When does this happen?
The best definition for "normal" is the geometric one, as Minkowski defines in
en.wikisource.org/wiki/Translation:Space_and_Time
http://en.wikisource.org/wiki/Page:De_Raum_Zeit_Minkowski_018.jpg
In Euclidean geometry,
the tangent line to a circle at a point P is perpendicular to the radius to that point
(http://en.wikipedia.org/wiki/Tangent_lines_to_circles)
By analogy, in Minkowski spacetime,
the tangent line to a Minkowski-circle (a hyperbola) at a point P is Minkowski-perpendicular to the radius to that point.
This has an immediate physical intrepretation: an inertial observer's sense of "space [at an instant]" (what events are simultaneous for that observer) is perpendicular to that observer's sense of "time [along his worldline]".
One good way of thinking about it is that when a timelike vector o is orthogonal to a spacelike vector s, an observer whose velocity four-vector is o considers s to be a vector of simultaneity. In other words, o points along that observer's time axis, and s could point along one of her spatial axes. (Of course this doesn't cover lightlike vectors or orthogonality of spacelike vectors to other spacelike vectors.) I have a treatment in this style in my SR book, http://www.lightandmatter.com/sr/ , at the beginning of the first chapter.
flyinjoe...I'm not sure I really understand the answers so far...
maybe this will help a bit...
http://en.wikipedia.org/wiki/Minkowski_diagram
The first three sections, at a minium, provide insights.
You know that Minkowski is four dimensional and Eucledean is just the three of space, right?
So as I see it [simple minded perhaps] is that just as a normal to a plane has one less degree of freedom than a normal to a line embedded in that plane, so too is a normal restricted by the addition of a time component.
If you read between the lines in Wiki where it says
...Space and time have properties which lead to different rules for the translation of coordinates in case of moving observers [different than Newtonian/Eucledean]...In the Minkowski diagram this relativity of simultaneity corresponds with the introduction of a separate path axis for the moving observer.
and you can probably visualize different paths leads to different tangents and normals...
  • · Replies 63 ·
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 22 ·
  • · Replies 55 ·
