Missing Water on Mars: Hydrated Crust Minerals May Explain
  • Thread starter BillTre
    Mars Water
0 replies · 3K views
TL;DR
Mars used to be wet, but is now dry.
The usual explanation is that the water was blown off, like the atmosphere, by the solar wind, after the planetary magnetic field went away (aided by Mars's lower that earth gravity).
Additional water may be stored, hydrated in minerals of Mars's crust.
The solar wind driven removal of water from Mars can only explain a portion of the water thought to have once existed there.
This process, indicated by the D/H ratio of normal hydrogen to its heavier form (deuterium) of Martian hydrogen, can only a count for the lower estimates of Martian water volumes.
Among alternative explanations, is a proposal that much water is tied up in hydrated minerals in rock of the crust.
Science mag news article.
Science research paper. (maybe open access, I can't tell)
Hydration of rocks in the crust is well known on earth. On earth, it has been proposed that 1/2 of the volume of the current oceans is tied up in crust minerals. Near surface hydrated Earth minerals are recycled into mantle rocks, by processes driving plate tectonics. This liberates some of the water bound to subducting minerals as volcanic gases.
This is not a process that goes on on Mars, indicating water in hydrated minerals might be irreversably trapped there on Mars.
Picture of their model:
Two-panel schematic of Martian water exchange: panel A is a flow diagram linking volcanism, atmosphere, polar caps, liquid water, space and crustal water with rate parameters; panel B shows three cross-sections for the Noachian, Hesperian and Amazonian epochs.
Text-only figure caption: Fig. 1 Schematic illustration of water sink and source fluxes considered in simulations, with panel A describing a box model of crustal water, escape and volcanic degassing, and panel B describing Noachian, Hesperian and Amazonian assumptions.
